Ana içeriğe geç
Optoma HD20 Air Filter Replacement
Neye ihtiyacın var
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 2.
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    FixBot'a Sor
    Yorum Ekle
  2. Optoma HD20 Air Filter Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Optoma HD20 Air Filter Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    FixBot'a Sor
    Yorum Ekle
  4. Optoma HD20 Air Filter Replacement: adım 4, 1 resimden 1.
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    FixBot'a Sor
    Yorum Ekle
  5. Optoma HD20 Air Filter Replacement, Air Filter: adım 5, 3 resimden 1. Optoma HD20 Air Filter Replacement, Air Filter: adım 5, 3 resimden 2. Optoma HD20 Air Filter Replacement, Air Filter: adım 5, 3 resimden 3.
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
    FixBot'a Sor
    Yorum Ekle
  6. Optoma HD20 Air Filter Replacement: adım 6, 1 resimden 1.
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Trever
1.282 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G23
4 Üyeler
1Rehber Yorum
There were no filters where the photos indicate.
Michael - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 72
Her zaman: 13,558
