Ana içeriğe geç
Optoma HD20 Color Wheel Replacement
Neye ihtiyacın var
    1. Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 1. Optoma HD20 Color Wheel Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 2.
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      FixBot'a Sor
      Yorum Ekle
    2. Optoma HD20 Color Wheel Replacement: adım 2, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Optoma HD20 Color Wheel Replacement: adım 3, 1 resimden 1.
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      FixBot'a Sor
      Yorum Ekle
    4. Optoma HD20 Color Wheel Replacement: adım 4, 1 resimden 1.
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      FixBot'a Sor
      Yorum Ekle
    1. Optoma HD20 Color Wheel Replacement, Color Wheel: adım 5, 1 resimden 1.
      • Use the plastic opening tool to remove the wiring.
      FixBot'a Sor
      Yorum Ekle
    2. Optoma HD20 Color Wheel Replacement: adım 6, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
      FixBot'a Sor
      Yorum Ekle
    3. Optoma HD20 Color Wheel Replacement: adım 7, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
      FixBot'a Sor
      Yorum Ekle
    4. Optoma HD20 Color Wheel Replacement: adım 8, 1 resimden 1.
      • Using a flat head screw driver unscrew the back part to release the color wheel.
      • Do this carefully because these screws do not pull out.
      FixBot'a Sor
      Yorum Ekle
    5. Optoma HD20 Color Wheel Replacement: adım 9, 1 resimden 1.
      • Once unscrewed, remove the color wheel, and replace the part.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Trever
1.282 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G23
4 Üyeler
13 adet Kılavuz yazıldı
3Kılavuz Yorumları
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
srbaucom - Yanıt Paylaş
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter - Yanıt Paylaş
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 46
Her zaman: 9,901
