Ana içeriğe geç
Optoma HD20 Fan Replacement
Neye ihtiyacın var
    1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 2.
      • Twist the focal cap clockwise until it is fully extended.
      • Remove the focal cap by pulling it straight out.
      FixBot'a Sor
      Yorum Ekle
    2. Optoma HD20 Fan Replacement: adım 2, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Optoma HD20 Fan Replacement: adım 3, 1 resimden 1.
      • Use a plastic opening tool to gently pry the top cover off of the device.
      • It is easier to pry off the cover from the back side just above the HDMI ports.
      FixBot'a Sor
      Yorum Ekle
    4. Optoma HD20 Fan Replacement: adım 4, 1 resimden 1.
      • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
      • Remove the ribbon by disconnecting it from the main circuit board.
      • Lift up the clip holding it down and pull the ribbon out.
      FixBot'a Sor
      Yorum Ekle
    1. Optoma HD20 Fan Replacement, Fan: adım 5, 1 resimden 1.
      • Peel off the tape that is holding the metal casing down.
      FixBot'a Sor
      Yorum Ekle
    2. Optoma HD20 Fan Replacement: adım 6, 2 resimden 1. Optoma HD20 Fan Replacement: adım 6, 2 resimden 2.
      • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
      • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
      FixBot'a Sor
      Yorum Ekle
    3. Optoma HD20 Fan Replacement: adım 7, 1 resimden 1.
      • Remove the metal casing by lifting it up off of the circuit board.
      FixBot'a Sor
      Yorum Ekle
    4. Optoma HD20 Fan Replacement: adım 8, 1 resimden 1.
      • Unplug the six wires stemming from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    5. Optoma HD20 Fan Replacement: adım 9, 1 resimden 1.
      • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
      FixBot'a Sor
      Yorum Ekle
    6. Optoma HD20 Fan Replacement: adım 10, 1 resimden 1.
      • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    7. Optoma HD20 Fan Replacement: adım 11, 1 resimden 1.
      • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. Optoma HD20 Fan Replacement: adım 12, 1 resimden 1.
      • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
      • Lift the plastic backing to remove it.
      FixBot'a Sor
      Yorum Ekle
    9. Optoma HD20 Fan Replacement: adım 13, 1 resimden 1.
      • Ensure all screws are removed
      • Lift up the motherboard and take out the metal container beneath it.
      • Do this very carefully as there is still one cable attached.
      FixBot'a Sor
      Yorum Ekle
    10. Optoma HD20 Fan Replacement: adım 14, 1 resimden 1.
      • Unplug the white connector underneath the right side of the circuit board.
      • To remove, pinch both sides of the connector and pull it away from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    11. Optoma HD20 Fan Replacement: adım 15, 2 resimden 1. Optoma HD20 Fan Replacement: adım 15, 2 resimden 2.
      • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
      FixBot'a Sor
      Yorum Ekle
    12. Optoma HD20 Fan Replacement: adım 16, 2 resimden 1. Optoma HD20 Fan Replacement: adım 16, 2 resimden 2.
      • Pull the fan away from the metal housing unit.
      • Gently lift the fan up and out of the device. The fan is now removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Trever
1.282 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G23
4 Üyeler
13 adet Kılavuz yazıldı
6Kılavuz Yorumları
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - Yanıt Paylaş
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - Yanıt Paylaş
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague - Yanıt Paylaş
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - Yanıt Paylaş
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 93
Her zaman: 14,441
