Ana içeriğe geç
Optoma HD20 Focal Lens Replacement
Neye ihtiyacın var
  1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: adım 1, 2 resimden 2.
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    FixBot'a Sor
    Yorum Ekle
  2. Optoma HD20 Focal Lens Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Optoma HD20 Focal Lens Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    FixBot'a Sor
    Yorum Ekle
  4. Optoma HD20 Focal Lens Replacement: adım 4, 1 resimden 1.
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    FixBot'a Sor
    Yorum Ekle
  5. Optoma HD20 Focal Lens Replacement, Focal Lens: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
    FixBot'a Sor
    Yorum Ekle
  6. Optoma HD20 Focal Lens Replacement: adım 6, 1 resimden 1.
    • Remove the focal lens by twisting it clockwise until it comes off.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trever
1.282 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G23
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 53
Her zaman: 4,818
