Ana içeriğe geç
Optoma HD20 Light Bulb Replacement
Neye ihtiyacın var
  1. Optoma HD20 Light Bulb Replacement, Rear Panel: adım 1, 2 resimden 1. Optoma HD20 Light Bulb Replacement, Rear Panel: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
    FixBot'a Sor
    Yorum Ekle
  2. Optoma HD20 Light Bulb Replacement: adım 2, 1 resimden 1.
    • Lift the panel off of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Optoma HD20 Light Bulb Replacement, Light Bulb Casing: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
    • The screws don't come out all the way.
    FixBot'a Sor
    Yorum Ekle
  4. Optoma HD20 Light Bulb Replacement: adım 4, 3 resimden 1. Optoma HD20 Light Bulb Replacement: adım 4, 3 resimden 2. Optoma HD20 Light Bulb Replacement: adım 4, 3 resimden 3.
    • Remove the light bulb casing from the device.
    • Steps 5-9 are unnecessary if the replacement light bulb comes with housing.
    FixBot'a Sor
    Yorum Ekle
  5. Optoma HD20 Light Bulb Replacement, Light Bulb: adım 5, 1 resimden 1.
    • Remove the three 4.5 mm screws on the light bulb case.
    FixBot'a Sor
    Yorum Ekle
  6. Optoma HD20 Light Bulb Replacement: adım 6, 1 resimden 1.
    • Carefully remove the light bulb insulator from the light bulb casing.
    FixBot'a Sor
    Yorum Ekle
  7. Optoma HD20 Light Bulb Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Gently pull the wires off of the pins using tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. Optoma HD20 Light Bulb Replacement: adım 8, 1 resimden 1.
    • Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Optoma HD20 Light Bulb Replacement: adım 9, 2 resimden 1. Optoma HD20 Light Bulb Replacement: adım 9, 2 resimden 2.
    • Remove the casing, then gently pull out the old light bulb and replace it with the new one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Trever
1.282 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G23
4 Üyeler
5Kılavuz Yorumları
I recently replaced my bulb for the third time and the insulator had grown brittle I am guessing from the heat and it broke. I can't seem to find this part for sale anywhere. Does anyone know if is possible to purchase it?
Thomas - Yanıt Paylaş
The screws in step 8 are extremely hard to get off. I went and bought proper screwdrivers before even attempting since theyre small, but in a day I've only managed to get one off and I'm having to resort to other tactics, even using a drill to just grind the heads off.
dv01_ - Yanıt Paylaş
king@okinlamps.com
Need LAD60 20PCS
kingshen92 - Yanıt Paylaş
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
Taringajohn - Yanıt Paylaş
my hd 20 projects dull images i recently replaced my bulb for the first time successfully and i followed as per menu trying to bulb reset but it is not working and still image is dull how to solve the problem
kumar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 74
Her zaman: 12,779
