Ana içeriğe geç
Optoma HD72 Color Wheel Replacement
Neye ihtiyacın var
    1. Optoma HD72 Color Wheel Replacement, Upper Case: adım 1, 2 resimden 1. Optoma HD72 Color Wheel Replacement, Upper Case: adım 1, 2 resimden 2.
      • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Optoma HD72 Color Wheel Replacement: adım 2, 1 resimden 1.
      • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
      • Disconnect the two cables that connect the top case to the motherboard.
      • Lift the upper case up and off.
      FixBot'a Sor
      Yorum Ekle
    1. Optoma HD72 Color Wheel Replacement, Motherboard: adım 3, 3 resimden 1. Optoma HD72 Color Wheel Replacement, Motherboard: adım 3, 3 resimden 2. Optoma HD72 Color Wheel Replacement, Motherboard: adım 3, 3 resimden 3.
      • Disconnect all of the cables that are connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Optoma HD72 Color Wheel Replacement: adım 4, 1 resimden 1.
      • Remove the four 2 mm Phillips screws that secure the motherboard.
      • Lift the motherboard up and out of the chassis.
      FixBot'a Sor
      Yorum Ekle
    1. Optoma HD72 Color Wheel Replacement, Color Wheel: adım 5, 3 resimden 1. Optoma HD72 Color Wheel Replacement, Color Wheel: adım 5, 3 resimden 2. Optoma HD72 Color Wheel Replacement, Color Wheel: adım 5, 3 resimden 3.
      • Remove the three 2 mm Phillips screws that secure the black housing.
      • Lift the black housing off.
      FixBot'a Sor
      Yorum Ekle
    2. Optoma HD72 Color Wheel Replacement: adım 6, 2 resimden 1. Optoma HD72 Color Wheel Replacement: adım 6, 2 resimden 2.
      • Remove the single 2 mm Phillips screw that secures the color wheel.
      • Lift the color wheel up and out of its housing.
      FixBot'a Sor
      Yorum Ekle
    3. Optoma HD72 Color Wheel Replacement: adım 7, 3 resimden 1. Optoma HD72 Color Wheel Replacement: adım 7, 3 resimden 2. Optoma HD72 Color Wheel Replacement: adım 7, 3 resimden 3.
      • Remove the single 2 mm Phillips screw that secures the circuit board to the side of the color wheel.
      • Use a sharp tool to cut the zip tie that secures the color wheel’s cables.
      • Remove the color wheel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 430
