Ana içeriğe geç
Optoma HD72 Fan Replacement
Neye ihtiyacın var
  1. Optoma HD72 Fan Replacement, Upper Case: adım 1, 2 resimden 1. Optoma HD72 Fan Replacement, Upper Case: adım 1, 2 resimden 2.
    • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Optoma HD72 Fan Replacement: adım 2, 1 resimden 1.
    • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
    • Disconnect the two cables that connect the top case to the motherboard.
    • Lift the upper case up and off.
    FixBot'a Sor
    Yorum Ekle
  3. Optoma HD72 Fan Replacement, Motherboard: adım 3, 3 resimden 1. Optoma HD72 Fan Replacement, Motherboard: adım 3, 3 resimden 2. Optoma HD72 Fan Replacement, Motherboard: adım 3, 3 resimden 3.
    • Disconnect all of the cables that are connected to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Optoma HD72 Fan Replacement: adım 4, 1 resimden 1.
    • Remove the four 2 mm Phillips screws that secure the motherboard.
    • Lift the motherboard up and out of the chassis.
    FixBot'a Sor
    Yorum Ekle
  5. Optoma HD72 Fan Replacement, Fan: adım 5, 3 resimden 1. Optoma HD72 Fan Replacement, Fan: adım 5, 3 resimden 2. Optoma HD72 Fan Replacement, Fan: adım 5, 3 resimden 3.
    • Remove the three 2 mm Phillips screws that secure the black housing.
    • Lift the black housing off.
    FixBot'a Sor
    Yorum Ekle
  6. Optoma HD72 Fan Replacement: adım 6, 3 resimden 1. Optoma HD72 Fan Replacement: adım 6, 3 resimden 2. Optoma HD72 Fan Replacement: adım 6, 3 resimden 3.
    • Remove the two 2 mm Phillips screws that secure the fan.
    • Lift the fan up and out of the chassis.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 59
Her zaman: 749
