Ana içeriğe geç
Optoma HD72 Projection Lamp Replacement
Neye ihtiyacın var
  1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
    • Remove the panel.
    FixBot'a Sor
    Yorum Ekle
  2. Optoma HD72 Projection Lamp Replacement: adım 2, 1 resimden 1.
    • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
    FixBot'a Sor
    Yorum Ekle
  3. Optoma HD72 Projection Lamp Replacement: adım 3, 2 resimden 1. Optoma HD72 Projection Lamp Replacement: adım 3, 2 resimden 2.
    • Lift the panel off of the device using the metal handle.
    • Disconnect the pink wires from the black plastic housing.
    FixBot'a Sor
    Yorum Ekle
  4. Optoma HD72 Projection Lamp Replacement: adım 4, 3 resimden 1. Optoma HD72 Projection Lamp Replacement: adım 4, 3 resimden 2. Optoma HD72 Projection Lamp Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
    • Remove the projection lamp casing by gently lifting the bulb from its housing.
    FixBot'a Sor
    Yorum Ekle
  5. Optoma HD72 Projection Lamp Replacement: adım 5, 2 resimden 1. Optoma HD72 Projection Lamp Replacement: adım 5, 2 resimden 2.
    • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
    • The second photo is what the completed bulb housing should look like.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 35
Her zaman: 277
