Ana içeriğe geç
Optoma PRO360W Bulb Replacement
Neye ihtiyacın var
  1. Optoma PRO360W Bulb Replacement, Unplug projector: adım 1, 1 resimden 1.
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Optoma PRO360W Bulb Replacement: adım 2, 1 resimden 1.
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Optoma PRO360W Bulb Replacement: adım 3, 1 resimden 1.
    • Unscrew the bulb screws on either side of the silver plate.
  4. Optoma PRO360W Bulb Replacement: adım 4, 1 resimden 1.
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Optoma PRO360W Bulb Replacement: adım 5, 1 resimden 1.
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Optoma PRO360W Bulb Replacement: adım 6, 1 resimden 1.
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Optoma PRO360W Bulb Replacement: adım 7, 1 resimden 1.
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Optoma PRO360W Bulb Replacement: adım 8, 1 resimden 1.
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Optoma PRO360W Bulb Replacement: adım 9, 1 resimden 1.
    • Dispose of the bulb by sending it to a recycling center.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Desiree Benitez
128 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 847
