Ana içeriğe geç
Oral-B Vitality Power Button Replacement
Neye ihtiyacın var
  1. Oral-B Vitality Power Button Replacement, Power Button: adım 1, 3 resimden 1. Oral-B Vitality Power Button Replacement, Power Button: adım 1, 3 resimden 2. Oral-B Vitality Power Button Replacement, Power Button: adım 1, 3 resimden 3.
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: adım 2, 1 resimden 1.
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: adım 3, 3 resimden 1. Oral-B Vitality Power Button Replacement: adım 3, 3 resimden 2. Oral-B Vitality Power Button Replacement: adım 3, 3 resimden 3.
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: adım 4, 1 resimden 1.
    • Attach the new button by soldering the 4 terminals with new solder.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Grady Bennett
503 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Harley Fall 2017 IUPUI, Team S2-G1, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G1
3 Üyeler
8 adet Kılavuz yazıldı
4 Yorum
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - Yanıt
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - Yanıt
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - Yanıt
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 55
Son 30 gün: 230
Her zaman: 9,839
