Ana içeriğe geç
Orbic Wonder Battery Replacement
Neye ihtiyacın var
    1. Orbic Wonder Battery Replacement, Battery: adım 1, 3 resimden 1. Orbic Wonder Battery Replacement, Battery: adım 1, 3 resimden 2. Orbic Wonder Battery Replacement, Battery: adım 1, 3 resimden 3.
      • Remove two 2mm TR9 Torx screws from the bottoms of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Orbic Wonder Battery Replacement: adım 2, 3 resimden 1. Orbic Wonder Battery Replacement: adım 2, 3 resimden 2. Orbic Wonder Battery Replacement: adım 2, 3 resimden 3.
      • There is a border between the black phone backing and the silver screen.
      • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
      • When the halves are parted correctly, the gap should look like this.
      • Be careful to avoid damaging any connecting circuitry between the two halves.
      FixBot'a Sor
      Yorum Ekle
    3. Orbic Wonder Battery Replacement: adım 3, 3 resimden 1. Orbic Wonder Battery Replacement: adım 3, 3 resimden 2. Orbic Wonder Battery Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
      • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Orbic Wonder Battery Replacement: adım 4, 3 resimden 1. Orbic Wonder Battery Replacement: adım 4, 3 resimden 2. Orbic Wonder Battery Replacement: adım 4, 3 resimden 3.
      $3.99
      • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
      • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Orbic Wonder Battery Replacement: adım 5, 3 resimden 1. Orbic Wonder Battery Replacement: adım 5, 3 resimden 2. Orbic Wonder Battery Replacement: adım 5, 3 resimden 3.
      • There is a black flap on the bottom of the battery.
      • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
where do you buy the replacement battery at ?
ricotoomo - Yanıt Paylaş
Where can I buy a replacement battery
Robert Smith - Yanıt Paylaş
Thank you big help your smart
gansterms123 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 8,236
