Ana içeriğe geç
Orbic Wonder Battery Replacement
Neye ihtiyacın var
  1. Orbic Wonder Battery Replacement, Battery: adım 1, 3 resimden 1. Orbic Wonder Battery Replacement, Battery: adım 1, 3 resimden 2. Orbic Wonder Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
  2. Orbic Wonder Battery Replacement: adım 2, 3 resimden 1. Orbic Wonder Battery Replacement: adım 2, 3 resimden 2. Orbic Wonder Battery Replacement: adım 2, 3 resimden 3.
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
  3. Orbic Wonder Battery Replacement: adım 3, 3 resimden 1. Orbic Wonder Battery Replacement: adım 3, 3 resimden 2. Orbic Wonder Battery Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
  4. Orbic Wonder Battery Replacement: adım 4, 3 resimden 1. Orbic Wonder Battery Replacement: adım 4, 3 resimden 2. Orbic Wonder Battery Replacement: adım 4, 3 resimden 3.
    $3.99
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
  5. Orbic Wonder Battery Replacement: adım 5, 3 resimden 1. Orbic Wonder Battery Replacement: adım 5, 3 resimden 2. Orbic Wonder Battery Replacement: adım 5, 3 resimden 3.
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
where do you buy the replacement battery at ?
ricotoomo - Yanıt
Where can I buy a replacement battery
Robert Smith -
Thank you big help your smart
gansterms123 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 37
Her zaman: 7,513
