Ana içeriğe geç
Orbic Wonder Charging Port Circuit Board Replacement
Neye ihtiyacın var
  1. Orbic Wonder Charging Port Circuit Board Replacement, Battery: adım 1, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement, Battery: adım 1, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement, Battery: adım 1, 3 resimden 3.
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
  2. Orbic Wonder Charging Port Circuit Board Replacement: adım 2, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement: adım 2, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement: adım 2, 3 resimden 3.
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
  3. Orbic Wonder Charging Port Circuit Board Replacement: adım 3, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement: adım 3, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
  4. Orbic Wonder Charging Port Circuit Board Replacement: adım 4, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement: adım 4, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement: adım 4, 3 resimden 3.
    $3.99
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
  5. Orbic Wonder Charging Port Circuit Board Replacement: adım 5, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement: adım 5, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement: adım 5, 3 resimden 3.
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
  6. Orbic Wonder Charging Port Circuit Board Replacement, Speaker: adım 6, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement, Speaker: adım 6, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement, Speaker: adım 6, 3 resimden 3.
    $7.95
    • Remove the anti-static wrist strap.
    • Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
    • Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
  7. Orbic Wonder Charging Port Circuit Board Replacement: adım 7, 2 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement: adım 7, 2 resimden 2.
    $3.99
  8. Orbic Wonder Charging Port Circuit Board Replacement, Charging Port Circuit Board: adım 8, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement, Charging Port Circuit Board: adım 8, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement, Charging Port Circuit Board: adım 8, 3 resimden 3.
    $3.99
    • Detach the metal casing at the bottom of the phone.
    • Unplug the cable connector.
    • Use a pair of angled tweezers to unplug the black wire.
  9. Orbic Wonder Charging Port Circuit Board Replacement: adım 9, 3 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement: adım 9, 3 resimden 2. Orbic Wonder Charging Port Circuit Board Replacement: adım 9, 3 resimden 3.
    • Using a pair of angled tweezers, disconnect the connector chip.
    • With the angled tweezers, gently lift (but do not remove) the green circuit board from the phone.
  10. Orbic Wonder Charging Port Circuit Board Replacement: adım 10, 2 resimden 1. Orbic Wonder Charging Port Circuit Board Replacement: adım 10, 2 resimden 2.
    • Using a pair of angled tweezers, disconnect the attachment to the microphone labeled "JD," and completely remove the circuit board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 35
Her zaman: 1,396
