Ana içeriğe geç
Ordro HDV-D395 Back Case Replacement
Neye ihtiyacın var
  1. Ordro HDV-D395 Back Case Replacement, Back Case: adım 1, 2 resimden 1. Ordro HDV-D395 Back Case Replacement, Back Case: adım 1, 2 resimden 2.
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Back Case Replacement: adım 2, 1 resimden 1.
    • Pull battery out of slot.
  3. Ordro HDV-D395 Back Case Replacement: adım 3, 1 resimden 1.
    • Unfold the screen from the side of the camera.
  4. Ordro HDV-D395 Back Case Replacement: adım 4, 1 resimden 1.
    • Twist the screen so that the screen is facing downward.
  5. Ordro HDV-D395 Back Case Replacement: adım 5, 2 resimden 1. Ordro HDV-D395 Back Case Replacement: adım 5, 2 resimden 2.
    • Unscrew the four screws on the side (length 2.9 mm) with a JIS #000 screwdriver.
    • Unscrew the three screws on the bottom (length 7.7 mm) with a JIS #000 screwdriver.
  6. Ordro HDV-D395 Back Case Replacement: adım 6, 1 resimden 1.
    • Pull apart the camera into two pieces by pulling the side with the screen away from the main body of the camera.
  7. Ordro HDV-D395 Back Case Replacement: adım 7, 2 resimden 1. Ordro HDV-D395 Back Case Replacement: adım 7, 2 resimden 2.
    • Unscrew the two screws (size 4.75 mm) with a PH #00 screwdriver.
    • Unscrew the screw (size 7.65 mm) with a PH #00 screwdriver.
  8. Ordro HDV-D395 Back Case Replacement: adım 8, 1 resimden 1.
    • Take the back case off by pulling it away from the main body.
    • Be careful not to tear the white strap that connects the back case to the main body.
  9. Ordro HDV-D395 Back Case Replacement: adım 9, 1 resimden 1.
    • Unscrew all four screws (length 4.13 mm) on the inside of the case with a PH #00 screwdriver.
  10. Ordro HDV-D395 Back Case Replacement: adım 10, 1 resimden 1.
    • Pull the board away from the back case.
Sonuç
Mostafa Abdulaleem
181 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Baechle Fall 2018 IUPUI, Team S1-G3, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 297
