Ana içeriğe geç
Ordro HDV-D395 Lens Replacement
Neye ihtiyacın var
  1. Ordro HDV-D395 Lens Replacement, Lens: adım 1, 2 resimden 1. Ordro HDV-D395 Lens Replacement, Lens: adım 1, 2 resimden 2.
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Lens Replacement: adım 2, 1 resimden 1.
    • Pull battery out of slot.
  3. Ordro HDV-D395 Lens Replacement: adım 3, 1 resimden 1.
    • Remove the three screws (length 7.7 mm) from the bottom of the outer case using a JIS000 screwdriver.
  4. Ordro HDV-D395 Lens Replacement: adım 4, 2 resimden 1. Ordro HDV-D395 Lens Replacement: adım 4, 2 resimden 2.
    • Remove plastic casing hiding screws from the strap side of the casing.
    • Unscrew the three screws (length 4.75 mm) using a PH000 screwdriver.
    • Unscrew the two screws (length 6.4 mm) using a JIS000 screwdriver.
  5. Ordro HDV-D395 Lens Replacement: adım 5, 1 resimden 1.
    • Unscrew the four screws (2.9 mm length) from the screen side of the casing using a JIS000 screwdriver.
  6. Ordro HDV-D395 Lens Replacement: adım 6, 1 resimden 1.
    • Remove both side casings by gripping the sides with your hands and pulling gently.
  7. Ordro HDV-D395 Lens Replacement: adım 7, 3 resimden 1. Ordro HDV-D395 Lens Replacement: adım 7, 3 resimden 2. Ordro HDV-D395 Lens Replacement: adım 7, 3 resimden 3.
    • Although it requires extra steps, it is advised that you remove the motherboard and screen to ensure that nothing is damaged in the process of replacing the lens.
    • Unscrew the seven screws (length 4.22 mm) from the motherboard using a PH000 screwdriver.
    • Pull out or desolder all connected cords from motherboard.
  8. Ordro HDV-D395 Lens Replacement: adım 8, 2 resimden 1. Ordro HDV-D395 Lens Replacement: adım 8, 2 resimden 2.
    • Remove top of the casing to reveal the screws on lens.
    • Unscrew the four screws (size 4.90 mm) using a PH00 screwdriver.
  9. Ordro HDV-D395 Lens Replacement: adım 9, 3 resimden 1. Ordro HDV-D395 Lens Replacement: adım 9, 3 resimden 2. Ordro HDV-D395 Lens Replacement: adım 9, 3 resimden 3.
    • Pull out lens.
    • Remove cord from lens.
Sonuç
Nathan Mcintyre
303 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Baechle Fall 2018 IUPUI, Team S1-G3, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 230
