Ana içeriğe geç
Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement
Neye ihtiyacın var
  1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement, Beater Bar/Agitator and Belt: adım 1, 3 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement, Beater Bar/Agitator and Belt: adım 1, 3 resimden 2. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement, Beater Bar/Agitator and Belt: adım 1, 3 resimden 3.
    • Remove five screws with a long neck Phillips #2 screwdriver.
  2. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 2, 3 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 2, 3 resimden 2. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 2, 3 resimden 3.
    • Remove the cover by lifting straight up.
    • Be sure to gently remove in case of bending the plastic.
  3. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 3, 2 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 3, 2 resimden 2.
    • Next remove the agitator and belt.
    • Pull the belt out first so it is easier to lift up the agitator.
    • Retrieve the new beater bar and belt.
  4. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 4, 3 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 4, 3 resimden 2. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 4, 3 resimden 3.
    • If it is difficult to remove the belt, remove the side panel first.
    • Remove the screw and slide the panel to remove it.
  5. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 5, 3 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 5, 3 resimden 2. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 5, 3 resimden 3.
    • Connect the belt to the motor.
    • Attach the other side to the beater bar.
    • Slowly pull the beater bar into the grooves and push it down.
    • To make the process easier be sure to stretch the belt out manually before replacing.
  6. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 6, 2 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 6, 2 resimden 2.
    • Make sure it is secure in both sides.
  7. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 7, 2 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 7, 2 resimden 2.
    • Slide the side panel back on and tighten the screw.
  8. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 8, 3 resimden 1. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 8, 3 resimden 2. Oreck XL U4120H2 Beater Bar/Agitator and Belt Replacement: adım 8, 3 resimden 3.
    • Place the bottom back on the vacuum.
    • Screw in all five of the Phillips #2 screws to reassemble your vacuum.
Sonuç
If you follow the correct steps in order the vacuum should be running and cleaning up messes faster than before.
Isaiah Allard
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 171
