Ana içeriğe geç
Oregon Scientific Meep! X2 Battery Replacement
Neye ihtiyacın var
    1. Oregon Scientific Meep! X2 Battery Replacement, Rear Casing: adım 1, 1 resimden 1.
      • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Battery Replacement: adım 2, 3 resimden 1. Oregon Scientific Meep! X2 Battery Replacement: adım 2, 3 resimden 2. Oregon Scientific Meep! X2 Battery Replacement: adım 2, 3 resimden 3.
      • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Oregon Scientific Meep! X2 Battery Replacement: adım 3, 3 resimden 1. Oregon Scientific Meep! X2 Battery Replacement: adım 3, 3 resimden 2. Oregon Scientific Meep! X2 Battery Replacement: adım 3, 3 resimden 3.
      • Use the plastic opening tools to undo the clips around the edges of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: adım 4, 3 resimden 1. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: adım 4, 3 resimden 2. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: adım 4, 3 resimden 3.
      • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
      • Pull lightly on the ribbon cable to remove it.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: adım 5, 2 resimden 1. Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: adım 5, 2 resimden 2.
      • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
      FixBot'a Sor
      Yorum Ekle
    3. Oregon Scientific Meep! X2 Battery Replacement: adım 6, 2 resimden 1. Oregon Scientific Meep! X2 Battery Replacement: adım 6, 2 resimden 2.
      • Use a soldering station to unsolder the battery wires from the motherboard.
      • In the case of screen or screen sensor replacement, disregard desoldering steps.
      FixBot'a Sor
      Yorum Ekle
Sonuç
J'mel Henneman
864 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Blackwell Winter 2015 USF Tampa, Team 9-1, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G1
3 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 32
Her zaman: 1,875
