Ana içeriğe geç
Oregon Scientific Meep! X2 Screen Sensor Replacement
Neye ihtiyacın var
    1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Rear Casing: adım 1, 1 resimden 1.
      • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 2, 3 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 2, 3 resimden 2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 2, 3 resimden 3.
      • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 3, 3 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 3, 3 resimden 2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 3, 3 resimden 3.
      • Use the plastic opening tools to undo the clips around the edges of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Power Button: adım 4, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Power Button: adım 4, 2 resimden 2.
      • Use a tweezer to gently pull the power button sensor out of the case's slot.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 5, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 5, 2 resimden 2.
      • Use the soldering station to unsolder and remove the power button from the motherboard.
      • In the case of screen or screen sensor replacement, disregard desoldering steps.
      FixBot'a Sor
      Yorum Ekle
    1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Microphone: adım 6, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Microphone: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use your tweezers to gently remove the microphone from the slot in the casing.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 7, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 7, 2 resimden 2.
      • Unsolder the microphone unit from the motherboard using the soldering station.
      FixBot'a Sor
      Yorum Ekle
    1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Cameras: adım 8, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Cameras: adım 8, 2 resimden 2.
      • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 9, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 9, 2 resimden 2.
      • Pry the second camera out of its slot with one of the plastic opening tools.
      • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
      FixBot'a Sor
      Yorum Ekle
    3. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 10, 1 resimden 1.
      • Release the black security clip on the ribbon cable with your plastic opening tool.
      • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Motherboard: adım 11, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Motherboard: adım 11, 2 resimden 2.
      • Undo the security clips on the ribbon cable connection by placing the plastic opening tool between the black and white parts of the clip. Pull downard toward the gold ribbon cable.
      • Once the left and right clips are undone, remove the gold ribbon cable from that connection by gently pulling it out.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 12, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 12, 2 resimden 2.
      • Remove the two phillips #00 (4.5mm x 3mm)screws located on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 13, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 13, 2 resimden 2.
      • Lift the silver, rectangular blocker in order to expose the right phillips screw #00 (4mm x 3.5mm).
      • Unscrew the left and right phillips #00 (4mm x 3.5mm)screws.
      • Once unscrewed, gently lift the motherboard from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Screen: adım 14, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Screen: adım 14, 2 resimden 2.
      • Remove the 10 phillips #00(3.5mm x 4mm) screws around the metal framing of the screen.
      • Leave the clear tape on the back of the screen until you are ready to remove it from the white plastic casing.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 15, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 15, 2 resimden 2.
      • Slowly remove the metal frame and screen from the white casing by gently pulling up on the ends of the metal frame.
      FixBot'a Sor
      Yorum Ekle
    3. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 16, 1 resimden 1.
      • Remove the plastic tape from the back of the screen.
      • Carefully separate the screen from the metal framing.
      FixBot'a Sor
      Yorum Ekle
    1. Oregon Scientific Meep! X2 Screen Sensor Replacement, Screen Sensor: adım 17, 1 resimden 1.
      • Use the spudger to undo the ribbon cable security clip located on the far left of the screen sensor.
      FixBot'a Sor
      Yorum Ekle
    2. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 18, 2 resimden 1. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 18, 2 resimden 2.
      • Unscrew each of the 14 black, phillips #00 (3mm x 3mm) phillips head screws from the screen sensor.
      FixBot'a Sor
      Yorum Ekle
    3. Oregon Scientific Meep! X2 Screen Sensor Replacement: adım 19, 1 resimden 1.
      • Use the spudger to gently undo the sensor from the white casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
J'mel Henneman
864 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Blackwell Winter 2015 USF Tampa, Team 9-1, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G1
3 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 650
