Ana içeriğe geç
Oregon Scientific RM318PA A/C Power Adapter Replacement
  1. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: adım 1, 2 resimden 1. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: adım 1, 2 resimden 2.
    • To access the A/C Power Adapter connection, remove the battery cover, located on the back of the clock.
    comment ajuster l'heure.
    jean-guy geoffroy - Yanıt
  2. Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: adım 2, 2 resimden 1. Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: adım 2, 2 resimden 2.
    • To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
  3. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Socket: adım 3, 1 resimden 1.
    • Gently pull the A/C Power Adapter from the socket, to the left of the batteries.
  4. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Tip: adım 4, 1 resimden 1.
    • To plug in the A/C Power Adapter, insert the tip into the socket, located to the left of the batteries, and press firmly.
    • Be sure that you are inserting an A/C Power Adapter and not a D/C Power Adapter. Inserting the improper cord could cause damage to the device.
  5. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Cord: adım 5, 1 resimden 1.
    • Once the A/C Power Adapter tip is inserted in the socket, guide the cord through a notch directly below.
    comment ajuster heure sur model rm318pa
Sonuç
Bir başkası bu kılavuzu tamamladı.
4 Yorum
i need operating manual for model no.rm318pa.please send to…gjgeoff1@outlook.fr
i need operating manuel
jean-guy geoffroy -
When you say make sure to insert AC power adapter what do you mean. It clearly says DC3V on the clock. Could you post the picture of the adapter without cord over the label?
Alex Olekh - Yanıt
Alex! Yes, right you are! DC not AC and Oregon Scientific will not answer my email requests. I am !#^&@@!
Ty Ford - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 3,363
