Ana içeriğe geç
Giriş
Replacing the batteries may be a simple solution for a clock that has stopped functioning. Battery replacement can be completed in just a few steps.
Aletler
Hiçbir alet belirtilmedi.
Parçalar
  1. Locate the battery compartment cover on the back of the clock.
    • Locate the battery compartment cover on the back of the clock.
  2. To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
    • To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
  3. Android Tamir Setleri
    A new screen or battery is one kit away.
    Hemen Alışveriş Yapın
  4. Using your fingertips and lifting up, take out the two AA batteries.
    • Using your fingertips and lifting up, take out the two AA batteries.
  5. Once the old batteries are removed, insert new AA batteries.
    • Once the old batteries are removed, insert new AA batteries.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 5
Her zaman: 477
