Ana içeriğe geç
Oregon Scientific RM318PA Lens Replacement
Neye ihtiyacın var
  1. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: adım 1, 3 resimden 1. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: adım 1, 3 resimden 2. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: adım 1, 3 resimden 3.
    • Hold clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
    FixBot'a Sor
    Yorum Ekle
  2. Oregon Scientific RM318PA Lens Replacement, Batteries: adım 2, 1 resimden 1.
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
    FixBot'a Sor
    Yorum Ekle
  3. Oregon Scientific RM318PA Lens Replacement, Projection Arm: adım 3, 2 resimden 1. Oregon Scientific RM318PA Lens Replacement, Projection Arm: adım 3, 2 resimden 2.
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
    FixBot'a Sor
    Yorum Ekle
  4. Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: adım 4, 2 resimden 1. Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: adım 4, 2 resimden 2.
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
    FixBot'a Sor
    Yorum Ekle
  5. Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: adım 5, 2 resimden 1. Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: adım 5, 2 resimden 2.
    • Use a Plastic Opening Tool to pry open the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a Spudger to pry at the side of the projection arm.
    FixBot'a Sor
    Yorum Ekle
  6. Oregon Scientific RM318PA Lens Replacement, Projection Beam: adım 6, 3 resimden 1. Oregon Scientific RM318PA Lens Replacement, Projection Beam: adım 6, 3 resimden 2. Oregon Scientific RM318PA Lens Replacement, Projection Beam: adım 6, 3 resimden 3.
    • Turn the clock on its side. Slide the focus wheel forward with your thumb.
    • The Projection Beam and Focus Wheel Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
    FixBot'a Sor
    Yorum Ekle
  7. Oregon Scientific RM318PA Lens Replacement, The Lens: adım 7, 1 resimden 1.
    • The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
    FixBot'a Sor
    Yorum Ekle
  8. Oregon Scientific RM318PA Lens Replacement, Tape: adım 8, 1 resimden 1.
    • Apply tape to the lens for safe removal and prevention of injury.
    FixBot'a Sor
    Yorum Ekle
  9. Oregon Scientific RM318PA Lens Replacement, Focus Knob: adım 9, 2 resimden 1. Oregon Scientific RM318PA Lens Replacement, Focus Knob: adım 9, 2 resimden 2.
    • Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip.
    • Pry apart the pieces of casing holding the focus knob in place and remove the knob.
    FixBot'a Sor
    Yorum Ekle
  10. Oregon Scientific RM318PA Lens Replacement, Internal Casing: adım 10, 3 resimden 1. Oregon Scientific RM318PA Lens Replacement, Internal Casing: adım 10, 3 resimden 2. Oregon Scientific RM318PA Lens Replacement, Internal Casing: adım 10, 3 resimden 3.
    • Insert the spudger into the opening above the hinge on the side of the casing.
    • Press down firmly until the case opens.
    FixBot'a Sor
    Yorum Ekle
  11. Oregon Scientific RM318PA Lens Replacement, Lens Removal: adım 11, 2 resimden 1. Oregon Scientific RM318PA Lens Replacement, Lens Removal: adım 11, 2 resimden 2.
    • Pull apart the casing and gently slide lens from pocket.
    • Be sure to replace with a concave lens.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maxine Holden
500 İtibar
4 adet Kılavuz yazıldı
1Rehber Yorum
Hi, I’ve this alarm clock with missing piezo/speaker, can anyone take a picture of the main board showing the pads for it?
Mastto geppetto - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 40
Her zaman: 3,140
