Ana içeriğe geç
Oregon Scientific RM318PA Power Switch Replacement
Neye ihtiyacın var
  1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: adım 1, 3 resimden 1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: adım 1, 3 resimden 2. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: adım 1, 3 resimden 3.
    • Hold clock so that the clock face is facing away from you.
    • Using your thumbs, push up on the battery cover.
    • Once battery cover is removed, pull down on AC Adapter Jack.
    FixBot'a Sor
    Yorum Ekle
  2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: adım 2, 1 resimden 1.
    • Use one hand to stabilize the clock.
    • Using your other hand, push batteries toward spring and pull out at an angle.
    FixBot'a Sor
    Yorum Ekle
  3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: adım 3, 3 resimden 1. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: adım 3, 3 resimden 2. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: adım 3, 3 resimden 3.
    • Use a Plastic Opening Tool to pry off the silver casing on the back.
    • Pry at the top of device.
    • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
    • On/Off switch should come off with casing.
    FixBot'a Sor
    Yorum Ekle
  4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: adım 4, 2 resimden 1. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: adım 4, 2 resimden 2.
    • Insert switch into slot as shown in picture. Push in until you hear a "click."
    • Replace the back of the clock by pressing cover back into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Maxine Holden
500 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 41
Her zaman: 1,842
