Ana içeriğe geç
Oreva FX-82MS Battery Replacement
Neye ihtiyacın var
  1. Oreva FX-82MS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the calculator by pressing the [Shift] button and then press the [AC][OFF] button, (while keeping the [Shift] button pressed down).
  2. Oreva FX-82MS Battery Replacement: adım 2, 2 resimden 1. Oreva FX-82MS Battery Replacement: adım 2, 2 resimden 2.
    • Flip the calculator over so that the back panel faces up.
    • Use a Phillips #0 screwdriver to remove six, 1.2 mm screws starting from the upper right corner.
  3. Oreva FX-82MS Battery Replacement: adım 3, 2 resimden 1. Oreva FX-82MS Battery Replacement: adım 3, 2 resimden 2.
    • Remove the back cover and put it to the side.
  4. Oreva FX-82MS Battery Replacement: adım 4, 2 resimden 1. Oreva FX-82MS Battery Replacement: adım 4, 2 resimden 2.
    • Remove the two old batteries from the slots.
    • Be gentle when removing the batteries to avoid damaging the connectors.
  5. Oreva FX-82MS Battery Replacement: adım 5, 3 resimden 1. Oreva FX-82MS Battery Replacement: adım 5, 3 resimden 2. Oreva FX-82MS Battery Replacement: adım 5, 3 resimden 3.
    • Place the two new AAA batteries into the calculator, one by one.
    • Be sure that the direction of the + and - signs on your battery match the signs at the bottom of the battery compartment.
    • Place the case on back of the calculator.
  6. Oreva FX-82MS Battery Replacement: adım 6, 2 resimden 1. Oreva FX-82MS Battery Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #0 screwdriver to replace the 1.2 mm screws on the back case.
  7. Oreva FX-82MS Battery Replacement: adım 7, 1 resimden 1.
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Prarthit patel
196 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 73
Her zaman: 2,214
