Ana içeriğe geç
Osmo Mobile Bluetooth Module Replacement
Neye ihtiyacın var
  1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: adım 1, 2 resimden 1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: adım 1, 2 resimden 2.
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
    FixBot'a Sor
    Yorum Ekle
  2. Osmo Mobile Bluetooth Module Replacement: adım 2, 2 resimden 1. Osmo Mobile Bluetooth Module Replacement: adım 2, 2 resimden 2.
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
    FixBot'a Sor
    Yorum Ekle
  3. Osmo Mobile Bluetooth Module Replacement: adım 3, 1 resimden 1.
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Osmo Mobile Bluetooth Module Replacement: adım 4, 2 resimden 1. Osmo Mobile Bluetooth Module Replacement: adım 4, 2 resimden 2.
    • Remove joystick by gently pulling away from handle
    FixBot'a Sor
    Yorum Ekle
  5. Osmo Mobile Bluetooth Module Replacement: adım 5, 3 resimden 1. Osmo Mobile Bluetooth Module Replacement: adım 5, 3 resimden 2. Osmo Mobile Bluetooth Module Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
    FixBot'a Sor
    Yorum Ekle
  6. Osmo Mobile Bluetooth Module Replacement: adım 6, 3 resimden 1. Osmo Mobile Bluetooth Module Replacement: adım 6, 3 resimden 2. Osmo Mobile Bluetooth Module Replacement: adım 6, 3 resimden 3.
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
    FixBot'a Sor
    Yorum Ekle
  7. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: adım 7, 3 resimden 1. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: adım 7, 3 resimden 2. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: adım 7, 3 resimden 3.
    • Locate and remove the black screw found at the base of the grey mounting plate.
    • Remove the grey face plate.
    FixBot'a Sor
    Yorum Ekle
  8. Osmo Mobile Bluetooth Module Replacement: adım 8, 2 resimden 1. Osmo Mobile Bluetooth Module Replacement: adım 8, 2 resimden 2.
    • Open the battery hatch and remove it by using the tweezers to press the hinge into the device.
    • Remove the black screw located underneath where the battery hatch was.
    FixBot'a Sor
    Yorum Ekle
  9. Osmo Mobile Bluetooth Module Replacement: adım 9, 2 resimden 1. Osmo Mobile Bluetooth Module Replacement: adım 9, 2 resimden 2.
    • Use the spudger to remove the front handle casing by sliding the spudger into the area between the handle grooves.
    • Slide the spudger around the groove to find the 6 clasps that hold the front part of the handle, and unclasp them.
    • Take off the front handle section to reveal the whole interior of the device.
    FixBot'a Sor
    Yorum Ekle
  10. Osmo Mobile Bluetooth Module Replacement: adım 10, 3 resimden 1. Osmo Mobile Bluetooth Module Replacement: adım 10, 3 resimden 2. Osmo Mobile Bluetooth Module Replacement: adım 10, 3 resimden 3.
    • Locate and remove the black screw in the center of the motherboard chip.
    • Remove motherboard and replace.
    FixBot'a Sor
    Yorum Ekle
Sonuç
William Tyler Wills
432 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 43
Her zaman: 2,272
