Ana içeriğe geç
Osmo Mobile Charging Port Replacement
Neye ihtiyacın var
  1. Osmo Mobile Charging Port Replacement, Osmo Mobile Handle Disassembly: adım 1, 2 resimden 1. Osmo Mobile Charging Port Replacement, Osmo Mobile Handle Disassembly: adım 1, 2 resimden 2.
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Charging Port Replacement: adım 2, 2 resimden 1. Osmo Mobile Charging Port Replacement: adım 2, 2 resimden 2.
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Charging Port Replacement: adım 3, 1 resimden 1.
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Charging Port Replacement: adım 4, 2 resimden 1. Osmo Mobile Charging Port Replacement: adım 4, 2 resimden 2.
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Charging Port Replacement: adım 5, 3 resimden 1. Osmo Mobile Charging Port Replacement: adım 5, 3 resimden 2. Osmo Mobile Charging Port Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Charging Port Replacement: adım 6, 3 resimden 1. Osmo Mobile Charging Port Replacement: adım 6, 3 resimden 2. Osmo Mobile Charging Port Replacement: adım 6, 3 resimden 3.
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Charging Port Replacement, Charging Port: adım 7, 1 resimden 1.
    • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
    • Lift faceplate holding joystick module.
  8. Osmo Mobile Charging Port Replacement: adım 8, 1 resimden 1.
    • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
  9. Osmo Mobile Charging Port Replacement: adım 9, 1 resimden 1.
    • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
  10. Osmo Mobile Charging Port Replacement: adım 10, 1 resimden 1.
    • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
    • Replace charging module.
Sonuç
William Tyler Wills
426 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G1
4 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
Where can I buy a replacement port? Can’t find one with google.
patchdrury - Yanıt
Where can I buy the part. ?
John M O'Donovan - Yanıt
Which version Osmo Mobile is this for? I need one for ver. 3
Nick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 2,739
