Ana içeriğe geç
Oster 16-Speed Blender Container Replacement
  1. Oster 16-Speed Blender Container Replacement, Container: adım 1, 2 resimden 1. Oster 16-Speed Blender Container Replacement, Container: adım 1, 2 resimden 2.
    • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
    FixBot'a Sor
    Yorum Ekle
  2. Oster 16-Speed Blender Container Replacement: adım 2, 2 resimden 1. Oster 16-Speed Blender Container Replacement: adım 2, 2 resimden 2.
    • Next, remove the lid from the Blender Container.
    FixBot'a Sor
    Yorum Ekle
  3. Oster 16-Speed Blender Container Replacement: adım 3, 2 resimden 1. Oster 16-Speed Blender Container Replacement: adım 3, 2 resimden 2.
    • Flip the container on its side so that the bottom faces you.
    • Now rotate the bottom counter-clockwise to remove it from the container.
    FixBot'a Sor
    Yorum Ekle
  4. Oster 16-Speed Blender Container Replacement: adım 4, 2 resimden 1. Oster 16-Speed Blender Container Replacement: adım 4, 2 resimden 2.
    • Now you will see the bottom of the blender blades once the bottom piece is removed
    • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
    FixBot'a Sor
    Yorum Ekle
  5. Oster 16-Speed Blender Container Replacement: adım 5, 1 resimden 1.
    • Now your container is separated.
    FixBot'a Sor
    Yorum Ekle
Sonuç
With your container separated, it can now be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
881 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-37, Maness Spring 2014 Cal Poly, Team 12-37, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G37
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,426
