Ana içeriğe geç
Oster 16-Speed Blender Container Replacement
Neye ihtiyacın var
  1. Oster 16-Speed Blender Container Replacement, Container: adım 1, 2 resimden 1. Oster 16-Speed Blender Container Replacement, Container: adım 1, 2 resimden 2.
    • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
  2. Oster 16-Speed Blender Container Replacement: adım 2, 2 resimden 1. Oster 16-Speed Blender Container Replacement: adım 2, 2 resimden 2.
    • Next, remove the lid from the Blender Container.
  3. Oster 16-Speed Blender Container Replacement: adım 3, 2 resimden 1. Oster 16-Speed Blender Container Replacement: adım 3, 2 resimden 2.
    • Flip the container on its side so that the bottom faces you.
    • Now rotate the bottom counter-clockwise to remove it from the container.
  4. Oster 16-Speed Blender Container Replacement: adım 4, 2 resimden 1. Oster 16-Speed Blender Container Replacement: adım 4, 2 resimden 2.
    • Now you will see the bottom of the blender blades once the bottom piece is removed
    • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
  5. Oster 16-Speed Blender Container Replacement: adım 5, 1 resimden 1.
    • Now your container is separated.
Sonuç
With your container separated, it can now be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
779 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-37, Maness Spring 2014 Cal Poly, Team 12-37, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G37
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,042
