Ana içeriğe geç
Oster 3905 Lever Spring Replacement
Neye ihtiyacın var
    1. Oster 3905 Lever Spring Replacement, Slot Levers: adım 1, 1 resimden 1.
      • Firmly grip your hand around the slot lever.
      FixBot'a Sor
      Yorum Ekle
    2. Oster 3905 Lever Spring Replacement: adım 2, 1 resimden 1.
      • Stabilize the toaster by placing your hand on top.
      FixBot'a Sor
      Yorum Ekle
    3. Oster 3905 Lever Spring Replacement: adım 3, 2 resimden 1. Oster 3905 Lever Spring Replacement: adım 3, 2 resimden 2.
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      FixBot'a Sor
      Yorum Ekle
    4. Oster 3905 Lever Spring Replacement: adım 4, 1 resimden 1.
      • Both slot levers can be removed.
      FixBot'a Sor
      Yorum Ekle
    1. Oster 3905 Lever Spring Replacement, Outer Shell: adım 5, 1 resimden 1.
      • Place the toaster upside down so the bottom is facing the ceiling.
      FixBot'a Sor
      Yorum Ekle
    2. Oster 3905 Lever Spring Replacement: adım 6, 2 resimden 1. Oster 3905 Lever Spring Replacement: adım 6, 2 resimden 2.
      • Take off both rubber feet using a small metal spudger.
      • Wedge a spudger under the feet and pull up to pop off.
      FixBot'a Sor
      Yorum Ekle
    3. Oster 3905 Lever Spring Replacement: adım 7, 1 resimden 1.
      • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
      • There are two screws under the rubber feet.
      FixBot'a Sor
      Yorum Ekle
    4. Oster 3905 Lever Spring Replacement: adım 8, 1 resimden 1.
      • Place the toaster right side up.
      FixBot'a Sor
      Yorum Ekle
    5. Oster 3905 Lever Spring Replacement: adım 9, 2 resimden 1. Oster 3905 Lever Spring Replacement: adım 9, 2 resimden 2.
      • Grab the outer shell firmly and pull up towards the face of the toaster.
      FixBot'a Sor
      Yorum Ekle
    6. Oster 3905 Lever Spring Replacement: adım 10, 1 resimden 1.
      • For this part, you might need to wiggle the toaster to get the outer shell off.
      • The shell will not completely come off until the motherboard is removed in the next step.
      FixBot'a Sor
      Yorum Ekle
    7. Oster 3905 Lever Spring Replacement: adım 11, 3 resimden 1. Oster 3905 Lever Spring Replacement: adım 11, 3 resimden 2. Oster 3905 Lever Spring Replacement: adım 11, 3 resimden 3.
      • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. Oster 3905 Lever Spring Replacement: adım 12, 2 resimden 1. Oster 3905 Lever Spring Replacement: adım 12, 2 resimden 2.
      • Take out the grey “cancel” and “bagel” buttons from the shell.
      FixBot'a Sor
      Yorum Ekle
    1. Oster 3905 Lever Spring Replacement, Lever Spring: adım 13, 2 resimden 1. Oster 3905 Lever Spring Replacement, Lever Spring: adım 13, 2 resimden 2.
      • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
      FixBot'a Sor
      Yorum Ekle
    2. Oster 3905 Lever Spring Replacement: adım 14, 2 resimden 1. Oster 3905 Lever Spring Replacement: adım 14, 2 resimden 2.
      • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
      FixBot'a Sor
      Yorum Ekle
    3. Oster 3905 Lever Spring Replacement: adım 15, 3 resimden 1. Oster 3905 Lever Spring Replacement: adım 15, 3 resimden 2. Oster 3905 Lever Spring Replacement: adım 15, 3 resimden 3.
      • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
      • Pull the metal spacer upwards to release from the toaster.
      FixBot'a Sor
      Yorum Ekle
    4. Oster 3905 Lever Spring Replacement: adım 16, 2 resimden 1. Oster 3905 Lever Spring Replacement: adım 16, 2 resimden 2.
      • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sydney Alcaraz
601 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-1, Bruce Fall 2016 CSU Fullerton, Team 2-1, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G1
5 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where's the fix?
D Unger - Yanıt Paylaş
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 3,465
