Ana içeriğe geç
Oster 3905 Retractable Cord Replacement
Neye ihtiyacın var
    1. Oster 3905 Retractable Cord Replacement, Slot Levers: adım 1, 1 resimden 1.
      • Firmly grip your hand around the slot lever.
      FixBot'a Sor
      Yorum Ekle
    2. Oster 3905 Retractable Cord Replacement: adım 2, 1 resimden 1.
      • Stabilize the toaster by placing your hand on top.
      FixBot'a Sor
      Yorum Ekle
    3. Oster 3905 Retractable Cord Replacement: adım 3, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 3, 2 resimden 2.
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      FixBot'a Sor
      Yorum Ekle
    4. Oster 3905 Retractable Cord Replacement: adım 4, 1 resimden 1.
      • Both slot levers can be removed.
      FixBot'a Sor
      Yorum Ekle
    1. Oster 3905 Retractable Cord Replacement, Outer Shell: adım 5, 1 resimden 1.
      • Place the toaster upside down so the bottom is facing the ceiling.
      FixBot'a Sor
      Yorum Ekle
    2. Oster 3905 Retractable Cord Replacement: adım 6, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 6, 2 resimden 2.
      • Take off both rubber feet using a small metal spudger.
      • Wedge a spudger under the feet and pull up to pop off.
      FixBot'a Sor
      Yorum Ekle
    3. Oster 3905 Retractable Cord Replacement: adım 7, 1 resimden 1.
      • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
      • There are two screws under the rubber feet.
      FixBot'a Sor
      Yorum Ekle
    4. Oster 3905 Retractable Cord Replacement: adım 8, 1 resimden 1.
      • Place the toaster right side up.
      FixBot'a Sor
      Yorum Ekle
    5. Oster 3905 Retractable Cord Replacement: adım 9, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 9, 2 resimden 2.
      • Grab the outer shell firmly and pull up towards the face of the toaster.
      FixBot'a Sor
      Yorum Ekle
    6. Oster 3905 Retractable Cord Replacement: adım 10, 1 resimden 1.
      • For this part, you might need to wiggle the toaster to get the outer shell off.
      • The shell will not completely come off until the motherboard is removed in the next step.
      FixBot'a Sor
      Yorum Ekle
    7. Oster 3905 Retractable Cord Replacement: adım 11, 3 resimden 1. Oster 3905 Retractable Cord Replacement: adım 11, 3 resimden 2. Oster 3905 Retractable Cord Replacement: adım 11, 3 resimden 3.
      • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. Oster 3905 Retractable Cord Replacement: adım 12, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 12, 2 resimden 2.
      • Take out the grey “cancel” and “bagel” buttons from the shell.
      FixBot'a Sor
      Yorum Ekle
    1. Oster 3905 Retractable Cord Replacement, Retractable Cord: adım 13, 1 resimden 1.
      • Rotate the toaster so that the back is facing towards you.
      FixBot'a Sor
      Yorum Ekle
    2. Oster 3905 Retractable Cord Replacement: adım 14, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 14, 2 resimden 2.
      • Use the PH#1 bit to remove one 8mm screw located above the wire on the casing.
      • Then use the same screw bit to remove two 10mm screws found at the bottom.
      FixBot'a Sor
      Yorum Ekle
    3. Oster 3905 Retractable Cord Replacement: adım 15, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 15, 2 resimden 2.
      • Using the metal spudger, pry next to the black clip found at the base of the toaster and the casing.
      • Push down to separate the casing from the toaster.
      FixBot'a Sor
      Yorum Ekle
    4. Oster 3905 Retractable Cord Replacement: adım 16, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 16, 2 resimden 2.
      • Gently tilt the casing towards the toaster as you pull up from the base.
      FixBot'a Sor
      Yorum Ekle
    5. Oster 3905 Retractable Cord Replacement: adım 17, 1 resimden 1.
      • Use the PH#1 bit to remove the three 8mm screws located on the back side of the casing.
      FixBot'a Sor
      Yorum Ekle
    6. Oster 3905 Retractable Cord Replacement: adım 18, 2 resimden 1. Oster 3905 Retractable Cord Replacement: adım 18, 2 resimden 2.
      • When opening the casing a metal spring may suddenly pop out.
      • Use the metal spudger to pry open the two halves of the casing.
      • If you are having some trouble only using the metal spudger do not be afraid of using your fingers to pry the casing apart.
      FixBot'a Sor
      Yorum Ekle
    7. Oster 3905 Retractable Cord Replacement: adım 19, 3 resimden 1. Oster 3905 Retractable Cord Replacement: adım 19, 3 resimden 2. Oster 3905 Retractable Cord Replacement: adım 19, 3 resimden 3.
      • Carefully remove the spool keeping your fingers on either side of the casing.
      • Tape down the metal spring to keep it from unraveling out of place.
      FixBot'a Sor
      Yorum Ekle
    8. Oster 3905 Retractable Cord Replacement: adım 20, 3 resimden 1. Oster 3905 Retractable Cord Replacement: adım 20, 3 resimden 2. Oster 3905 Retractable Cord Replacement: adım 20, 3 resimden 3.
      • Carefully unwind the power cord from the spool.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Dierkes
140 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-1, Bruce Fall 2016 CSU Fullerton, Team 2-1, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G1
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 927
