Ana içeriğe geç
Oster 6329 Bread Grabber Spring Replacement
Neye ihtiyacın var
  1. Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: adım 1, 2 resimden 1. Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: adım 1, 2 resimden 2.
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
    FixBot'a Sor
    Yorum Ekle
  2. Oster 6329 Bread Grabber Spring Replacement: adım 2, 1 resimden 1.
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
    FixBot'a Sor
    Yorum Ekle
  3. Oster 6329 Bread Grabber Spring Replacement: adım 3, 1 resimden 1.
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
    FixBot'a Sor
    Yorum Ekle
  4. Oster 6329 Bread Grabber Spring Replacement: adım 4, 2 resimden 1. Oster 6329 Bread Grabber Spring Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
    FixBot'a Sor
    Yorum Ekle
  5. Oster 6329 Bread Grabber Spring Replacement: adım 5, 2 resimden 1. Oster 6329 Bread Grabber Spring Replacement: adım 5, 2 resimden 2.
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
    FixBot'a Sor
    Yorum Ekle
  6. Oster 6329 Bread Grabber Spring Replacement, Bread Grabber Spring: adım 6, 1 resimden 1.
    • Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
    FixBot'a Sor
    Yorum Ekle
  7. Oster 6329 Bread Grabber Spring Replacement: adım 7, 1 resimden 1.
    • Locate the grabber spring.
    FixBot'a Sor
    Yorum Ekle
  8. Oster 6329 Bread Grabber Spring Replacement: adım 8, 1 resimden 1.
    • Use the large needle nose pliers to unwind the grabber spring from one side of the carriage to remove.
    • Repeat this step for the opposite side.
    FixBot'a Sor
    Yorum Ekle
  9. Oster 6329 Bread Grabber Spring Replacement: adım 9, 1 resimden 1.
    • Remove the old spring from the toaster unit to insert new.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Isaac Williams
237 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G15
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 1,277
