Ana içeriğe geç
Oster 6329 Bread Grabber Spring Replacement
  1. Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: adım 1, 2 resimden 1. Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: adım 1, 2 resimden 2.
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Bread Grabber Spring Replacement: adım 2, 1 resimden 1.
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Bread Grabber Spring Replacement: adım 3, 1 resimden 1.
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Bread Grabber Spring Replacement: adım 4, 2 resimden 1. Oster 6329 Bread Grabber Spring Replacement: adım 4, 2 resimden 2.
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Bread Grabber Spring Replacement: adım 5, 2 resimden 1. Oster 6329 Bread Grabber Spring Replacement: adım 5, 2 resimden 2.
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Bread Grabber Spring Replacement, Bread Grabber Spring: adım 6, 1 resimden 1.
    • Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
  7. Oster 6329 Bread Grabber Spring Replacement: adım 7, 1 resimden 1.
    • Locate the grabber spring.
  8. Oster 6329 Bread Grabber Spring Replacement: adım 8, 1 resimden 1.
    • Use the large needle nose pliers to unwind the grabber spring from one side of the carriage to remove.
    • Repeat this step for the opposite side.
  9. Oster 6329 Bread Grabber Spring Replacement: adım 9, 1 resimden 1.
    • Remove the old spring from the toaster unit to insert new.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Isaac Williams
225 İtibar
2 adet Kılavuz yazıldı
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G15
5 Üyeler
6 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 781
