Giriş
Replacing the spring can be somewhat difficult, so be prepared to deal with a little frustration when removing the spring.
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Insert the tweezers between the spring and the bottom of the lever to release the spring.
Neredeyse bitti!
Sonuç
