Ana içeriğe geç
Oster 6329 Outer Shell Removal
  1. Oster 6329 Outer Shell Removal, Outer Shell Removal: adım 1, 2 resimden 1. Oster 6329 Outer Shell Removal, Outer Shell Removal: adım 1, 2 resimden 2.
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Outer Shell Removal: adım 2, 1 resimden 1.
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Outer Shell Removal: adım 3, 1 resimden 1.
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Outer Shell Removal: adım 4, 2 resimden 1. Oster 6329 Outer Shell Removal: adım 4, 2 resimden 2.
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Outer Shell Removal: adım 5, 2 resimden 1. Oster 6329 Outer Shell Removal: adım 5, 2 resimden 2.
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
Sonuç
Isaac Williams
225 İtibar
2 adet Kılavuz yazıldı
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G15
5 Üyeler
6 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 1,667
