Ana içeriğe geç
Oster BLSTSS-PZO Power Cord Replacement
Neye ihtiyacın var
  1. Oster BLSTSS-PZO  Power Cord Replacement, Circuitboard: adım 1, 1 resimden 1.
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO  Power Cord Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO  Power Cord Replacement: adım 3, 1 resimden 1.
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO  Power Cord Replacement: adım 4, 2 resimden 1. Oster BLSTSS-PZO  Power Cord Replacement: adım 4, 2 resimden 2.
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO  Power Cord Replacement: adım 5, 3 resimden 1. Oster BLSTSS-PZO  Power Cord Replacement: adım 5, 3 resimden 2. Oster BLSTSS-PZO  Power Cord Replacement: adım 5, 3 resimden 3.
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
  6. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: adım 6, 3 resimden 1. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: adım 6, 3 resimden 2. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: adım 6, 3 resimden 3.
    • Locate petal prong on the end of the power cord.
    • Bend metal prong until it's straight with your finger.
  7. Oster BLSTSS-PZO  Power Cord Replacement: adım 7, 2 resimden 1. Oster BLSTSS-PZO  Power Cord Replacement: adım 7, 2 resimden 2.
    • Spring will pop out when you pull out metal prong
    • Pull prong out of the hole.
  8. Oster BLSTSS-PZO  Power Cord Replacement: adım 8, 3 resimden 1. Oster BLSTSS-PZO  Power Cord Replacement: adım 8, 3 resimden 2. Oster BLSTSS-PZO  Power Cord Replacement: adım 8, 3 resimden 3.
    • Pinch plastic prongs on base of blender to remove plastic securing device.
    • Remove plastic securing device.
    • Pull power cord out of blender base.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 194
