Ana içeriğe geç
Oster BLSTSS-PZO Blades & Seal Ring Replacement
  1. Oster BLSTSS-PZO Blades & Seal Ring Replacement, Blades & Seal Ring: adım 1, 1 resimden 1.
    • First, remove the blender container from the blender base by grabbing the container and lifting it up.
  2. Oster BLSTSS-PZO Blades & Seal Ring Replacement: adım 2, 1 resimden 1.
    • Flip the container, where the bottom faces you.
    • Then, rotate the bottom piece counter-clockwise to remove it from the container.
  3. Oster BLSTSS-PZO Blades & Seal Ring Replacement: adım 3, 1 resimden 1.
    • Carefully remove the bottom piece from the container.
    • Be careful while removing the blades from the container, as seeing they are very sharp and can hurt you.
  4. Oster BLSTSS-PZO Blades & Seal Ring Replacement: adım 4, 1 resimden 1.
    • Now, your container and blades are separated.
Sonuç
Farhan
104 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 470
