Ana içeriğe geç
Oster BLSTSS-PZO Circuitboard Replacement
Neye ihtiyacın var
  1. Oster BLSTSS-PZO Circuitboard  Replacement, Circuitboard: adım 1, 1 resimden 1.
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO Circuitboard  Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO Circuitboard  Replacement: adım 3, 1 resimden 1.
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO Circuitboard  Replacement: adım 4, 2 resimden 1. Oster BLSTSS-PZO Circuitboard  Replacement: adım 4, 2 resimden 2.
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO Circuitboard  Replacement: adım 5, 3 resimden 1. Oster BLSTSS-PZO Circuitboard  Replacement: adım 5, 3 resimden 2. Oster BLSTSS-PZO Circuitboard  Replacement: adım 5, 3 resimden 3.
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 504
