Ana içeriğe geç
Oster Blend-N-Go My Blend Blade Assembly Seal Replacement
Neye ihtiyacın var
  1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: adım 1, 2 resimden 1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: adım 1, 2 resimden 2.
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: adım 2, 3 resimden 1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: adım 2, 3 resimden 2. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: adım 2, 3 resimden 3.
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly: adım 3, 1 resimden 1.
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly Seal: adım 4, 1 resimden 1.
    • After separating the blade assembly from the blender bottle, position the plastic opening tool on either side of the seal in the blade assembly.
    • Wedge tool between seal and seal seat wall.
  5. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: adım 5, 1 resimden 1.
    • Gently pry the seal up while lifting seal out of the seal seat.
  6. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: adım 6, 2 resimden 1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: adım 6, 2 resimden 2.
    • Place and press the new seal into seal seat with finger.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Paul Long
710 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 1,933
