Ana içeriğe geç
Oster CKSTSTMD5-W Disassembly
Neye ihtiyacın var
  1. Oster CKSTSTMD5-W Disassembly, Oster CKSTSTMD5-W Disassembly: adım 1, 1 resimden 1.
    • Remove the plastic steamer tiers and make sure the device is unplugged.
  2. Oster CKSTSTMD5-W Disassembly: adım 2, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 2, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 2, 3 resimden 3.
    • Flip the device upside down so that the sticker is facing upwards.
    • Using your hands, carefully pry out the four rubber feet from each of the corners.
  3. Oster CKSTSTMD5-W Disassembly: adım 3, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 3, 2 resimden 2.
    • Using the JIS #1 screwdriver, remove four 12 mm screws from the four holes.
  4. Oster CKSTSTMD5-W Disassembly: adım 4, 1 resimden 1.
    • Once the four screws are removed, lift the bottom of the device off of the frame.
  5. Oster CKSTSTMD5-W Disassembly: adım 5, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 5, 2 resimden 2.
    • Use a pair of scissors to cut the zip tie binding the blue and brown wires together.
  6. Oster CKSTSTMD5-W Disassembly: adım 6, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 6, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 6, 3 resimden 3.
    • Using a socket wrench with a 7 mm bit, unscrew the nut from the center of the metal ring.
  7. Oster CKSTSTMD5-W Disassembly: adım 7, 1 resimden 1.
    • Remove the nut and the two washers from the center bolt.
  8. Oster CKSTSTMD5-W Disassembly: adım 8, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 8, 2 resimden 2.
    • Lift off the metal brace from the bolt in the center of the device.
  9. Oster CKSTSTMD5-W Disassembly: adım 9, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 9, 2 resimden 2.
    • From the center of the device, carefully grab the blue wire and lift the thermal fuse from its socket.
  10. Oster CKSTSTMD5-W Disassembly: adım 10, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 10, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 10, 3 resimden 3.
    • Using your hands, carefully lift the wires over the center bolt so that they are out of the way.
  11. Oster CKSTSTMD5-W Disassembly: adım 11, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 11, 2 resimden 2.
    • Using your index finger, carefully pry the metal sheeting out from under the wires.
  12. Oster CKSTSTMD5-W Disassembly: adım 12, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 12, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 12, 3 resimden 3.
    • Using the JIS #1 screwdriver, remove the two 12 mm screws from the left side of the device.
    • Lift off the white plastic brace.
  13. Oster CKSTSTMD5-W Disassembly: adım 13, 1 resimden 1.
    • Lift the white power cord out of its socket.
  14. Oster CKSTSTMD5-W Disassembly: adım 14, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 14, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 14, 3 resimden 3.
    • On the left-hand side of the device, carefully remove the indicator light from its place next to the timer by pulling on the heat protector covering the brown wire.
    • Be careful to ensure the bulb stays attached to the wire.
  15. Oster CKSTSTMD5-W Disassembly: adım 15, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 15, 2 resimden 2.
    • Using the JIS #1 screwdriver, remove the two 12 mm screws attached on each side of the timer.
  16. Oster CKSTSTMD5-W Disassembly: adım 16, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 16, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 16, 3 resimden 3.
    • Using your hands, carefully lift the white plastic barrier out of the device from the right side of the timer.
    • Be careful not to impede the blue and brown wires connecting the heating element to the timer.
  17. Oster CKSTSTMD5-W Disassembly: adım 17, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 17, 2 resimden 2.
    • Rotate the device so that the dial faces you.
    • Using the plastic opening tool, pry the white dial out of the timer socket.
  18. Oster CKSTSTMD5-W Disassembly: adım 18, 1 resimden 1.
    • Pull the white dial the rest of the way out of the socket.
  19. Oster CKSTSTMD5-W Disassembly: adım 19, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 19, 2 resimden 2.
    • Using the JIS #1 screwdriver, remove the two 12 mm screws from the top and bottom of the timer socket.
  20. Oster CKSTSTMD5-W Disassembly: adım 20, 1 resimden 1.
    • Using your fingers, pry out the black timer socket from the front hole.
  21. Oster CKSTSTMD5-W Disassembly: adım 21, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 21, 2 resimden 2.
    • Using your hands, carefully lift the timer out of the socket and away from the device.
    • Be careful not to pull too hard as to not break the wire connection.
  22. Oster CKSTSTMD5-W Disassembly: adım 22, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 22, 2 resimden 2.
    • Using the JIS #1 screwdriver, remove the two 4.3 mm screws from the right and left side of the timer.
    • Using your hands, lift off the black plastic cover.
  23. Oster CKSTSTMD5-W Disassembly: adım 23, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 23, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 23, 3 resimden 3.
  24. Oster CKSTSTMD5-W Disassembly: adım 24, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 24, 2 resimden 2.
    • Using the plastic opening tool, bend the 3 metal braces towards the outside of the timer so that the metal fits through the slots.
  25. Oster CKSTSTMD5-W Disassembly: adım 25, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 25, 2 resimden 2.
    • Lift the silver cover off of the timer.
  26. Oster CKSTSTMD5-W Disassembly: adım 26, 1 resimden 1.
    • Lift the metal silver plate off of the timer.
  27. Oster CKSTSTMD5-W Disassembly: adım 27, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 27, 2 resimden 2.
    • Using the JIS #1 screwdriver, remove the single 4.3mm screw from the top center of the timer.
  28. Oster CKSTSTMD5-W Disassembly: adım 28, 3 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 28, 3 resimden 2. Oster CKSTSTMD5-W Disassembly: adım 28, 3 resimden 3.
    • Lift the black plastic casing out from in between the front and back of the timer.
  29. Oster CKSTSTMD5-W Disassembly: adım 29, 2 resimden 1. Oster CKSTSTMD5-W Disassembly: adım 29, 2 resimden 2.
    • Rotate the timer 90 degrees to the left so that you can see it from the side.
    • Lift the silver back casing off of the timer.
Sonuç
Ekli Belgeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 266
