Ana içeriğe geç
Giriş
The heating coils may get dirty or in operable with use. This guide will show how to remove the heating coils in order to properly replace or clean them. Prior to replacing the heating coils, ensure that the heating problem is not caused by electrical errors as discussed in the troubleshooting page.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the bread pan.
    • Remove the bread pan.
  2. Remove the eight 22mm Phillips #1 screws from the grey lining. Remove the grey liner. Remove the grey liner.
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Remove the two 11mm Phillips #1 screws from the back of the device. Remove the two 11mm Phillips #1 screws from the back of the device.
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Pop off the top case using a spudger. Keep the spudger away from the control panel.
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Disconnect microcontroller and top lining. Ground yourself prior to disconnecting in order to avoid harming the inner electronics. Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  7. Remove the four 11mm Phillips #1 screws holding from the guard and inner lining. Remove small rectangular guard from bottom of liner Remove small rectangular guard from bottom of liner
    • Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
    • Remove small rectangular guard from bottom of liner
  8. Remove the inner liner.
    • Remove the inner liner.
    • The inner liner will be connected to the outer chamber with wires.
  9. Disconnect the red wires from the inner liner. Disconnect the red wires from the inner liner. Disconnect the red wires from the inner liner.
    • Disconnect the red wires from the inner liner.
  10. Remove the single 11mm Phillips #1 screw thats holding and inner lining in place. Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
    • Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
  11. Use a spudger to push out the connector found on the inner lining. Use a spudger to push out the connector found on the inner lining. Use a spudger to push out the connector found on the inner lining.
    • Use a spudger to push out the connector found on the inner lining.
  12. Remove lining. Remove lining.
    • Remove lining.
  13. Remove the two  11mm Phillips #1 screws from the inside of the chamber. Removal of the screws may also require a 1/4 socket wrench on the other side to prevent spinning. Removal of the screws may also require a 1/4 socket wrench on the other side to prevent spinning.
    • Remove the two 11mm Phillips #1 screws from the inside of the chamber.
    • Removal of the screws may also require a 1/4 socket wrench on the other side to prevent spinning.
  14. Remove the 11mm Phillips #1 screw from the heating coil. After you have  removed the screw the coils will pop out of place. After you have  removed the screw the coils will pop out of place.
    • Remove the 11mm Phillips #1 screw from the heating coil.
    • After you have removed the screw the coils will pop out of place.
Sonuç
Megan Saunders
677 İtibar
5 adet Kılavuz yazıldı
Takım
USF Tampa, Team S7-G5, Passmore Spring 2018 USF Tampa, Team S7-G5, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 76
