Ana içeriğe geç
Oster Expressbake CKSTBRTW20 Inner Chamber Replacement
Neye ihtiyacın var
  1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Top Panel Removal: adım 1, 1 resimden 1.
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 2, 3 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 2, 3 resimden 2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 2, 3 resimden 3.
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 3, 2 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 3, 2 resimden 2.
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 4, 2 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 4, 2 resimden 2.
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: adım 5, 3 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: adım 5, 3 resimden 2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: adım 5, 3 resimden 3.
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 6, 3 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 6, 3 resimden 2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 6, 3 resimden 3.
    • Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
    • Remove small rectangular guard from bottom of liner
  7. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 7, 1 resimden 1.
    • Remove the inner liner.
    • The inner liner will be connected to the outer chamber with wires.
  8. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 8, 3 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 8, 3 resimden 2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 8, 3 resimden 3.
    • Disconnect the red wires from the inner liner.
  9. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 9, 2 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 9, 2 resimden 2.
    • Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
  10. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 10, 3 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 10, 3 resimden 2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 10, 3 resimden 3.
    • Use a spudger to push out the connector found on the inner lining.
  11. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 11, 2 resimden 1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: adım 11, 2 resimden 2.
    • Remove lining.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Megan Saunders
701 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G5, Passmore Spring 2018 USF Tampa, Team S7-G5, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 452
