Ana içeriğe geç
Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement
Neye ihtiyacın var
  1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Removal: adım 1, 1 resimden 1.
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 2, 3 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 2, 3 resimden 2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 2, 3 resimden 3.
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 3, 2 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 3, 2 resimden 2.
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 4, 2 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 4, 2 resimden 2.
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: adım 5, 3 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: adım 5, 3 resimden 2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: adım 5, 3 resimden 3.
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 6, 2 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 6, 2 resimden 2.
    • Remove the two 11mm Phillips #1 screws from the top cover.
  7. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 7, 1 resimden 1.
    • Use spudger to pop the control panel out.
  8. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 8, 3 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 8, 3 resimden 2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 8, 3 resimden 3.
    • Remove the four 11mm Phillips #1 screws from the control panel.
  9. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 9, 3 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 9, 3 resimden 2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 9, 3 resimden 3.
    • Remove the two 11mm Phillips #1 screws from the button panel.
    • Flip the screen assembly over and remove the button panel.
  10. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 10, 2 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: adım 10, 2 resimden 2.
    • Remove and replace buttons as necessary.
Sonuç
Megan Saunders
701 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G5, Passmore Spring 2018 USF Tampa, Team S7-G5, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 226
