Ana içeriğe geç
Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement
Neye ihtiyacın var
  1. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement, Top Panel Removal: adım 1, 1 resimden 1.
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: adım 2, 3 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: adım 2, 3 resimden 2. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: adım 2, 3 resimden 3.
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: adım 3, 2 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: adım 3, 2 resimden 2.
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: adım 4, 2 resimden 1. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: adım 4, 2 resimden 2.
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
Sonuç
Megan Saunders
701 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G5, Passmore Spring 2018 USF Tampa, Team S7-G5, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 492
