Ana içeriğe geç
Ovation Acoustic Guitar String Replacement
Neye ihtiyacın var
  1. Ovation Acoustic Guitar String Replacement, Guitar String: adım 1, 1 resimden 1.
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: adım 2, 2 resimden 1. Ovation Acoustic Guitar String Replacement: adım 2, 2 resimden 2.
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: adım 3, 1 resimden 1.
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: adım 4, 2 resimden 1. Ovation Acoustic Guitar String Replacement: adım 4, 2 resimden 2.
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: adım 5, 1 resimden 1.
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: adım 6, 3 resimden 1. Ovation Acoustic Guitar String Replacement: adım 6, 3 resimden 2. Ovation Acoustic Guitar String Replacement: adım 6, 3 resimden 3.
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: adım 7, 2 resimden 1. Ovation Acoustic Guitar String Replacement: adım 7, 2 resimden 2.
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: adım 8, 3 resimden 1. Ovation Acoustic Guitar String Replacement: adım 8, 3 resimden 2. Ovation Acoustic Guitar String Replacement: adım 8, 3 resimden 3.
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: adım 9, 2 resimden 1. Ovation Acoustic Guitar String Replacement: adım 9, 2 resimden 2.
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
Bitiş Çizgisi
Rachel Galvan
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 587
