Ana içeriğe geç
P775DM3 GPU replacement
Neye ihtiyacın var
  1. P775DM3 GPU replacement, Battery: adım 1, 2 resimden 1. P775DM3 GPU replacement, Battery: adım 1, 2 resimden 2.
    • Unlock the lock circled in red.
    FixBot'a Sor
    Yorum Ekle
  2. P775DM3 GPU replacement: adım 2, 3 resimden 1. P775DM3 GPU replacement: adım 2, 3 resimden 2. P775DM3 GPU replacement: adım 2, 3 resimden 3.
    • Lift the battery while unlocking the lock circled in red.
    FixBot'a Sor
    Yorum Ekle
  3. P775DM3 GPU replacement, Access to major components: adım 3, 2 resimden 1. P775DM3 GPU replacement, Access to major components: adım 3, 2 resimden 2.
    • Unscrew the five screws circled in red.
    FixBot'a Sor
    Yorum Ekle
  4. P775DM3 GPU replacement: adım 4, 2 resimden 1. P775DM3 GPU replacement: adım 4, 2 resimden 2.
    • Slide the plate in the direction of the red arrow.
    FixBot'a Sor
    Yorum Ekle
  5. P775DM3 GPU replacement: adım 5, 2 resimden 1. P775DM3 GPU replacement: adım 5, 2 resimden 2.
    • Lift the plate.
    FixBot'a Sor
    Yorum Ekle
  6. P775DM3 GPU replacement, Cooler: adım 6, 3 resimden 1. P775DM3 GPU replacement, Cooler: adım 6, 3 resimden 2. P775DM3 GPU replacement, Cooler: adım 6, 3 resimden 3.
    • Unscrew the four large screws circled in green
    • Unscrew the five small screws circled in red
    • Lift the cooler with the two tabs circled in blue
    FixBot'a Sor
    Yorum Ekle
  7. P775DM3 GPU replacement, GPU: adım 7, 2 resimden 1. P775DM3 GPU replacement, GPU: adım 7, 2 resimden 2.
    • Unscrew the two screws circled in red
    FixBot'a Sor
    Yorum Ekle
  8. P775DM3 GPU replacement: adım 8, 3 resimden 1. P775DM3 GPU replacement: adım 8, 3 resimden 2. P775DM3 GPU replacement: adım 8, 3 resimden 3.
    • Lift the card to allow access to the red circled connector
    • Disconnect the red circled connector
    FixBot'a Sor
    Yorum Ekle
  9. P775DM3 GPU replacement: adım 9, 3 resimden 1. P775DM3 GPU replacement: adım 9, 3 resimden 2. P775DM3 GPU replacement: adım 9, 3 resimden 3.
    • Pull it in the direction of the red arrow
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device follow the following instructions in reverse order
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.589 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 922
