Ana içeriğe geç
P775DM3 Keyboard replacement
Neye ihtiyacın var
  1. P775DM3 Keyboard replacement, Battery: adım 1, 2 resimden 1. P775DM3 Keyboard replacement, Battery: adım 1, 2 resimden 2.
    • Unlock the lock circled in red.
  2. P775DM3 Keyboard replacement: adım 2, 3 resimden 1. P775DM3 Keyboard replacement: adım 2, 3 resimden 2. P775DM3 Keyboard replacement: adım 2, 3 resimden 3.
    • Lift the battery while unlocking the lock circled in red.
  3. P775DM3 Keyboard replacement, Access to major components: adım 3, 2 resimden 1. P775DM3 Keyboard replacement, Access to major components: adım 3, 2 resimden 2.
    • Unscrew the five screws circled in red.
  4. P775DM3 Keyboard replacement: adım 4, 2 resimden 1. P775DM3 Keyboard replacement: adım 4, 2 resimden 2.
    • Slide the plate in the direction of the red arrow.
  5. P775DM3 Keyboard replacement: adım 5, 2 resimden 1. P775DM3 Keyboard replacement: adım 5, 2 resimden 2.
    • Lift the plate.
  6. P775DM3 Keyboard replacement, Keyboard: adım 6, 2 resimden 1. P775DM3 Keyboard replacement, Keyboard: adım 6, 2 resimden 2.
    • Unscrew the two screws circled in red
  7. P775DM3 Keyboard replacement: adım 7, 3 resimden 1. P775DM3 Keyboard replacement: adım 7, 3 resimden 2. P775DM3 Keyboard replacement: adım 7, 3 resimden 3.
    • Press a paper clip in the three places marked in red
    • Lift the keyboard and feel free to put some strength
  8. P775DM3 Keyboard replacement: adım 8, 2 resimden 1. P775DM3 Keyboard replacement: adım 8, 2 resimden 2.
    • Disconnect the three framed connectors in red
  9. P775DM3 Keyboard replacement: adım 9, 2 resimden 1. P775DM3 Keyboard replacement: adım 9, 2 resimden 2.
    • Pull the white drawer in the direction of the arrow to unlock the connector
    • Disconnect the red circled connector
  10. P775DM3 Keyboard replacement: adım 10, 2 resimden 1. P775DM3 Keyboard replacement: adım 10, 2 resimden 2.
    • Pull the black drawer in the direction of the arrow to unlock the connector
  11. P775DM3 Keyboard replacement: adım 11, 3 resimden 1. P775DM3 Keyboard replacement: adım 11, 3 resimden 2. P775DM3 Keyboard replacement: adım 11, 3 resimden 3.
    • Lift the flap that holds the connector circled in red
    • Remove the keyboard
Sonuç
To reassemble your device, follow the instructions in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
30.884 İtibar
264 adet Kılavuz yazıldı
3 Yorum
I wish to know whether it’s possible to pry off the key to clean off the contacts. (I spilled coffee on the keyboard).
Fortunately for me, the key was on the edge of the board (the down arrow key). It was stuck on.
I lifted the key up as much as I could and I cleaned it with Deoxit. That did the trick. My keyboard is now working.
Thanks for the steps!
Clem Wang - Yanıt
Oops. Spoke too soon. There’s something wrong with the keyboard: the INSERT key (ESC -[2~ ) is stuck. Also, there’s a red light under the keyboard. I’m not sure what that all means…
Clem Wang - Yanıt
Great instructions, but for my laptop, step 7 only indicated three of seven places (the other four are the top centre of the keyboard, and the three points symmetrical to the 3 you’ve indacted, on the right hand side of the keyboard).
Josh Greifer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 34
Her zaman: 3,863
