Ana içeriğe geç
Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
P775DM3 Keyboard replacement
Neye ihtiyacın var
    1. P775DM3 Keyboard replacement, Battery: adım 1, 2 resimden 1. P775DM3 Keyboard replacement, Battery: adım 1, 2 resimden 2.
      • Unlock the lock circled in red.
      FixBot'a Sor
      Yorum Ekle
    2. P775DM3 Keyboard replacement: adım 2, 3 resimden 1. P775DM3 Keyboard replacement: adım 2, 3 resimden 2. P775DM3 Keyboard replacement: adım 2, 3 resimden 3.
      • Lift the battery while unlocking the lock circled in red.
      FixBot'a Sor
      Yorum Ekle
    1. P775DM3 Keyboard replacement, Access to major components: adım 3, 2 resimden 1. P775DM3 Keyboard replacement, Access to major components: adım 3, 2 resimden 2.
      • Unscrew the five screws circled in red.
      FixBot'a Sor
      Yorum Ekle
    2. P775DM3 Keyboard replacement: adım 4, 2 resimden 1. P775DM3 Keyboard replacement: adım 4, 2 resimden 2.
      • Slide the plate in the direction of the red arrow.
      FixBot'a Sor
      Yorum Ekle
    3. P775DM3 Keyboard replacement: adım 5, 2 resimden 1. P775DM3 Keyboard replacement: adım 5, 2 resimden 2.
      • Lift the plate.
      FixBot'a Sor
      Yorum Ekle
    1. P775DM3 Keyboard replacement, Keyboard: adım 6, 2 resimden 1. P775DM3 Keyboard replacement, Keyboard: adım 6, 2 resimden 2.
      • Unscrew the two screws circled in red
      FixBot'a Sor
      Yorum Ekle
    2. P775DM3 Keyboard replacement: adım 7, 3 resimden 1. P775DM3 Keyboard replacement: adım 7, 3 resimden 2. P775DM3 Keyboard replacement: adım 7, 3 resimden 3.
      • Press a paper clip in the three places marked in red
      • Lift the keyboard and feel free to put some strength
      FixBot'a Sor
      Yorum Ekle
    3. P775DM3 Keyboard replacement: adım 8, 2 resimden 1. P775DM3 Keyboard replacement: adım 8, 2 resimden 2.
      • Disconnect the three framed connectors in red
      FixBot'a Sor
      Yorum Ekle
    4. P775DM3 Keyboard replacement: adım 9, 2 resimden 1. P775DM3 Keyboard replacement: adım 9, 2 resimden 2.
      • Pull the white drawer in the direction of the arrow to unlock the connector
      • Disconnect the red circled connector
      FixBot'a Sor
      Yorum Ekle
    5. P775DM3 Keyboard replacement: adım 10, 2 resimden 1. P775DM3 Keyboard replacement: adım 10, 2 resimden 2.
      • Pull the black drawer in the direction of the arrow to unlock the connector
      FixBot'a Sor
      Yorum Ekle
    6. P775DM3 Keyboard replacement: adım 11, 3 resimden 1. P775DM3 Keyboard replacement: adım 11, 3 resimden 2. P775DM3 Keyboard replacement: adım 11, 3 resimden 3.
      • Lift the flap that holds the connector circled in red
      • Remove the keyboard
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow the instructions in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
90%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.634 İtibar
283 adet Kılavuz yazıldı
3Kılavuz Yorumları
I wish to know whether it’s possible to pry off the key to clean off the contacts. (I spilled coffee on the keyboard).
Fortunately for me, the key was on the edge of the board (the down arrow key). It was stuck on.
I lifted the key up as much as I could and I cleaned it with Deoxit. That did the trick. My keyboard is now working.
Thanks for the steps!
Clem Wang - Yanıt Paylaş
Oops. Spoke too soon. There’s something wrong with the keyboard: the INSERT key (ESC -[2~ ) is stuck. Also, there’s a red light under the keyboard. I’m not sure what that all means…
Great instructions, but for my laptop, step 7 only indicated three of seven places (the other four are the top centre of the keyboard, and the three points symmetrical to the 3 you’ve indacted, on the right hand side of the keyboard).
Josh Greifer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 56
Her zaman: 5,134
