Ana içeriğe geç
P775DM3 Motherboard replacement
Neye ihtiyacın var
  1. P775DM3 Motherboard replacement, Battery: adım 1, 2 resimden 1. P775DM3 Motherboard replacement, Battery: adım 1, 2 resimden 2.
    • Unlock the lock circled in red.
  2. P775DM3 Motherboard replacement: adım 2, 3 resimden 1. P775DM3 Motherboard replacement: adım 2, 3 resimden 2. P775DM3 Motherboard replacement: adım 2, 3 resimden 3.
    • Lift the battery while unlocking the lock circled in red.
  3. P775DM3 Motherboard replacement, Disk access: adım 3, 1 resimden 1.
    • Unscrew the two screws circled in red.
    • Slide the plate in the direction of the arrow.
  4. P775DM3 Motherboard replacement: adım 4, 2 resimden 1. P775DM3 Motherboard replacement: adım 4, 2 resimden 2.
    • Lift the plate
  5. P775DM3 Motherboard replacement, Hard Disk Drive: adım 5, 3 resimden 1. P775DM3 Motherboard replacement, Hard Disk Drive: adım 5, 3 resimden 2. P775DM3 Motherboard replacement, Hard Disk Drive: adım 5, 3 resimden 3.
    • Unscrew the screw circled in red.
    • Lift the disk with the green tab.
    • Remove the disk in the direction of the arrow.
  6. P775DM3 Motherboard replacement, M.2 SSD: adım 6, 2 resimden 1. P775DM3 Motherboard replacement, M.2 SSD: adım 6, 2 resimden 2.
  7. P775DM3 Motherboard replacement: adım 7, 2 resimden 1. P775DM3 Motherboard replacement: adım 7, 2 resimden 2.
    • Pull the SSD in the direction of the red arrow.
  8. P775DM3 Motherboard replacement, Access to major components: adım 8, 2 resimden 1. P775DM3 Motherboard replacement, Access to major components: adım 8, 2 resimden 2.
    • Unscrew the five screws circled in red.
  9. P775DM3 Motherboard replacement: adım 9, 2 resimden 1. P775DM3 Motherboard replacement: adım 9, 2 resimden 2.
    • Slide the plate in the direction of the red arrow.
  10. P775DM3 Motherboard replacement: adım 10, 2 resimden 1. P775DM3 Motherboard replacement: adım 10, 2 resimden 2.
    • Lift the plate.
  11. P775DM3 Motherboard replacement, Keyboard: adım 11, 2 resimden 1. P775DM3 Motherboard replacement, Keyboard: adım 11, 2 resimden 2.
  12. P775DM3 Motherboard replacement: adım 12, 3 resimden 1. P775DM3 Motherboard replacement: adım 12, 3 resimden 2. P775DM3 Motherboard replacement: adım 12, 3 resimden 3.
    • Press a paper clip in the three places marked in red
    • Lift the keyboard and feel free to put some strength
  13. P775DM3 Motherboard replacement: adım 13, 2 resimden 1. P775DM3 Motherboard replacement: adım 13, 2 resimden 2.
    • Disconnect the three framed connectors in red
  14. P775DM3 Motherboard replacement: adım 14, 2 resimden 1. P775DM3 Motherboard replacement: adım 14, 2 resimden 2.
    • Pull the white drawer in the direction of the arrow to unlock the connector
    • Disconnect the red circled connector
  15. P775DM3 Motherboard replacement: adım 15, 2 resimden 1. P775DM3 Motherboard replacement: adım 15, 2 resimden 2.
    • Pull the black drawer in the direction of the arrow to unlock the connector
  16. P775DM3 Motherboard replacement: adım 16, 3 resimden 1. P775DM3 Motherboard replacement: adım 16, 3 resimden 2. P775DM3 Motherboard replacement: adım 16, 3 resimden 3.
    • Lift the flap that holds the connector circled in red
    • Remove the keyboard
  17. P775DM3 Motherboard replacement, RAM: adım 17, 3 resimden 1. P775DM3 Motherboard replacement, RAM: adım 17, 3 resimden 2. P775DM3 Motherboard replacement, RAM: adım 17, 3 resimden 3.
    • Spread the two clips in red.
    • Remove the RAM card.
  18. P775DM3 Motherboard replacement, BIOS Battery: adım 18, 3 resimden 1. P775DM3 Motherboard replacement, BIOS Battery: adım 18, 3 resimden 2. P775DM3 Motherboard replacement, BIOS Battery: adım 18, 3 resimden 3.
    • Disconnect the connector circled in red.
    • Remove the battery.
  19. P775DM3 Motherboard replacement, WLAN card removal: adım 19, 3 resimden 1. P775DM3 Motherboard replacement, WLAN card removal: adım 19, 3 resimden 2. P775DM3 Motherboard replacement, WLAN card removal: adım 19, 3 resimden 3.
    • Disconnect the two connectors circled in green.
    • Remove the WLAN card.
  20. P775DM3 Motherboard replacement, Cooler: adım 20, 3 resimden 1. P775DM3 Motherboard replacement, Cooler: adım 20, 3 resimden 2. P775DM3 Motherboard replacement, Cooler: adım 20, 3 resimden 3.
    • Unscrew the four large screws circled in green
    • Unscrew the five small screws circled in red
    • Lift the cooler with the two tabs circled in blue
  21. P775DM3 Motherboard replacement, CPU: adım 21, 3 resimden 1. P775DM3 Motherboard replacement, CPU: adım 21, 3 resimden 2. P775DM3 Motherboard replacement, CPU: adım 21, 3 resimden 3.
    • Pull the lever circled in red in the direction of the red arrow while pressing on it.
    • Attention: Don't touch the underside of the processor, pick it up from the sides.
  22. P775DM3 Motherboard replacement, GPU: adım 22, 2 resimden 1. P775DM3 Motherboard replacement, GPU: adım 22, 2 resimden 2.
  23. P775DM3 Motherboard replacement: adım 23, 3 resimden 1. P775DM3 Motherboard replacement: adım 23, 3 resimden 2. P775DM3 Motherboard replacement: adım 23, 3 resimden 3.
    • Lift the card to allow access to the red circled connector
  24. P775DM3 Motherboard replacement: adım 24, 3 resimden 1. P775DM3 Motherboard replacement: adım 24, 3 resimden 2. P775DM3 Motherboard replacement: adım 24, 3 resimden 3.
    • Pull it in the direction of the red arrow
  25. P775DM3 Motherboard replacement, Fans: adım 25, 3 resimden 1. P775DM3 Motherboard replacement, Fans: adım 25, 3 resimden 2. P775DM3 Motherboard replacement, Fans: adım 25, 3 resimden 3.
    • Unscrew the three screws circled in red.
    • Disconnect the framed connector in red.
  26. P775DM3 Motherboard replacement: adım 26, 1 resimden 1.
    • Remove the fan.
  27. P775DM3 Motherboard replacement: adım 27, 3 resimden 1. P775DM3 Motherboard replacement: adım 27, 3 resimden 2. P775DM3 Motherboard replacement: adım 27, 3 resimden 3.
  28. P775DM3 Motherboard replacement: adım 28, 1 resimden 1.
    • Lift the fan.
  29. P775DM3 Motherboard replacement, Motherboard: adım 29, 3 resimden 1. P775DM3 Motherboard replacement, Motherboard: adım 29, 3 resimden 2. P775DM3 Motherboard replacement, Motherboard: adım 29, 3 resimden 3.
    • Lift the flap that holds the two connectors framed in red.
    • Disconnect the two framed connectors in red.
  30. P775DM3 Motherboard replacement: adım 30, 2 resimden 1. P775DM3 Motherboard replacement: adım 30, 2 resimden 2.
    • Disconnect the box connector in green.
  31. P775DM3 Motherboard replacement: adım 31, 2 resimden 1. P775DM3 Motherboard replacement: adım 31, 2 resimden 2.
    • Unscrew the twenty screws circled in red.
    • Unclip the edge of the case at the two places framed in green.
  32. P775DM3 Motherboard replacement: adım 32, 3 resimden 1. P775DM3 Motherboard replacement: adım 32, 3 resimden 2. P775DM3 Motherboard replacement: adım 32, 3 resimden 3.
    • Remove the top of the case.
  33. P775DM3 Motherboard replacement: adım 33, 3 resimden 1. P775DM3 Motherboard replacement: adım 33, 3 resimden 2. P775DM3 Motherboard replacement: adım 33, 3 resimden 3.
    • Remove the framed card in blue.
    • Remove the framed card in orange.
  34. P775DM3 Motherboard replacement: adım 34, 2 resimden 1. P775DM3 Motherboard replacement: adım 34, 2 resimden 2.
    • Disconnect the two framed connectors in green.
  35. P775DM3 Motherboard replacement: adım 35, 2 resimden 1. P775DM3 Motherboard replacement: adım 35, 2 resimden 2.
    • Disconnect the red circled connector.
  36. P775DM3 Motherboard replacement: adım 36, 2 resimden 1. P775DM3 Motherboard replacement: adım 36, 2 resimden 2.
    • Remove the motherboard.
Sonuç
To reassemble your device, follow the instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
31.100 İtibar
264 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 1,755
