Ana içeriğe geç
PCPanel Pro MIDI Controller Knob Replacement
Neye ihtiyacın var
  1. PCPanel Pro MIDI Controller Knob Replacement, Knob: adım 1, 2 resimden 1. PCPanel Pro MIDI Controller Knob Replacement, Knob: adım 1, 2 resimden 2.
    • Unplug the device.
  2. PCPanel Pro MIDI Controller Knob Replacement: adım 2, 2 resimden 1. PCPanel Pro MIDI Controller Knob Replacement: adım 2, 2 resimden 2.
    • Turn the affected knobs counter-clockwise until they cannot move anymore.
  3. PCPanel Pro MIDI Controller Knob Replacement: adım 3, 3 resimden 1. PCPanel Pro MIDI Controller Knob Replacement: adım 3, 3 resimden 2. PCPanel Pro MIDI Controller Knob Replacement: adım 3, 3 resimden 3.
    • Slowly pull upwards on the knob until it slides off.
    • Not much force needs to be used.
  4. PCPanel Pro MIDI Controller Knob Replacement: adım 4, 3 resimden 1. PCPanel Pro MIDI Controller Knob Replacement: adım 4, 3 resimden 2. PCPanel Pro MIDI Controller Knob Replacement: adım 4, 3 resimden 3.
    • Unscrew the fastening screw on the new knob until it is loose.
    • Depending on the knob, you may need to use a different tool to unscrew it. For the knob we had, we used a flathead screwdriver.
  5. PCPanel Pro MIDI Controller Knob Replacement: adım 5, 2 resimden 1. PCPanel Pro MIDI Controller Knob Replacement: adım 5, 2 resimden 2.
    • Place the replacement knob onto the MIDI controller.
  6. PCPanel Pro MIDI Controller Knob Replacement: adım 6, 3 resimden 1. PCPanel Pro MIDI Controller Knob Replacement: adım 6, 3 resimden 2. PCPanel Pro MIDI Controller Knob Replacement: adım 6, 3 resimden 3.
    • Screw the fastening screw into the MIDI controller. Make sure to leave a 2mm gap between the bottom of the replacement knob and the MIDI controller.
    • In this case, we used calipers to ensure the gap stayed at 2mm, however placing a few pieces of paper underneath the knob will be just fine. We are keeping this gap to ensure that the knob can still be pushed down.
  7. PCPanel Pro MIDI Controller Knob Replacement: adım 7, 3 resimden 1. PCPanel Pro MIDI Controller Knob Replacement: adım 7, 3 resimden 2. PCPanel Pro MIDI Controller Knob Replacement: adım 7, 3 resimden 3.
    • Plug in the MIDI controller and test the replacement knob. Ensure the knob can still be turned in either direction as well as pushed down.
  8. PCPanel Pro MIDI Controller Knob Replacement: adım 8, 1 resimden 1.
    • Repeat the steps for any replacement knobs needed.
    • Make sure all replaced knobs can still be turned in either direction as well as pushed down.
Sonuç
Make sure all of the knobs function as intended. To remove the knobs and put the old ones on, simply do the steps in reverse.
William Orlopp
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-1, Morris Spring 2024 UC Davis, Team 1-1, Morris Spring 2024 üyesi
UCD-MORRIS-S24S1G1
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 450
