Ana içeriğe geç
PDP Afterglow Fener Battery Replacement
Neye ihtiyacın var
  1. PDP Afterglow Fener Battery Replacement, Battery: adım 1, 2 resimden 1. PDP Afterglow Fener Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
  2. PDP Afterglow Fener Battery Replacement: adım 2, 2 resimden 1. PDP Afterglow Fener Battery Replacement: adım 2, 2 resimden 2.
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Murat Terzi
215 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G3
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 7,546
