Ana içeriğe geç
PDP Afterglow Fener LED Replacement
Neye ihtiyacın var
  1. PDP Afterglow Fener LED Replacement, LED: adım 1, 3 resimden 1. PDP Afterglow Fener LED Replacement, LED: adım 1, 3 resimden 2. PDP Afterglow Fener LED Replacement, LED: adım 1, 3 resimden 3.
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps and have removed the part that you unscrewed.
    FixBot'a Sor
    Yorum Ekle
  2. PDP Afterglow Fener LED Replacement: adım 2, 2 resimden 1. PDP Afterglow Fener LED Replacement: adım 2, 2 resimden 2.
    • First remove the battery from the headset, for instructions on how to do this correctly go here
    • Now take your J000 screwdriver and unscrew the screws that have a red circle around them.
    • Now remove the circuit board from the headset and flip it to the other side to be able to see the light/LED.
    FixBot'a Sor
    Yorum Ekle
  3. PDP Afterglow Fener LED Replacement: adım 3, 3 resimden 1. PDP Afterglow Fener LED Replacement: adım 3, 3 resimden 2. PDP Afterglow Fener LED Replacement: adım 3, 3 resimden 3.
    • Take your helping hand with alligator clips and put the printed circuit board on it.
    • This picture is a close up of the LED with the highlighted areas you need to unsoldered.
    • Now take your soldering iron and unsolder those four highlighted areas.
    • Your LED should come loose and you can now put on your new LED.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thomas Williams
512 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G3
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 1,090
